panasonic plasma screen test with no power ?
  • smai
    • Dec 2013
    • 69
    look at buying a used pany plasma anyway to tell if the display is bad/cracked without power and only led blinking ? im worried about buying it and getting it to power on only to find out it also needs a screen/display
    any thoughts ? besides an obvious crack
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: panasonic plasma screen test with no power ?
    Not much you can do--without firing it up....
    Many panel faults only become evident when running....
    Chances are--its only an electronic issue and the plate itself is just fine....
    TELEFIX
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Zelek11
      Panasonic Plasma screen interference on left half of screen
      by Zelek11
      My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
      This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
      10-14-2022, 04:54 PM
    • khelane
      test active pfc power with lamp test
      by khelane
      Hello
      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
      Is there a way...
      06-03-2025, 01:00 AM
    • grimacelord
      HP 15-EH1070wm - Black Screen With Power LED.
      by grimacelord
      I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
      First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
      01-28-2023, 10:50 AM
