Lg 42ld560
  • peterp
    • Jan 2014
    • 7
    • australia
    Lg 42ld560
    One for the LG experts. Has an intermittent " won't turn on " prob. I'm trying to determine whether it's a psu or main board issue. Error log in service mode lists ACDET as the main error. I believe AC DET signal is monitored by the micro on main board. When the signal is not present (psu prob) the tv is shut down. I've been told by LG tech support AC DET is always the main board at fault. I have my doubts that is correct. If anyone has any experience with this error log, I'd like to hear your opinion.
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Lg 42ld560
    sound familiar ,you would need to test psu on its own,to rule it out.
    you need to put up good pics of the psu and mainboard,and how its all connected together before you tear down.,and so we can see the connectors and there legends,to show you how to do this
    use manage attachments.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • peterp
      • Jan 2014
      • 7
      • australia
      Re: Lg 42ld560
      Don't be offended but I find that irrelevant. The reason being there is nothing to test unless it's in fault mode which happens once a week.
      Perhaps I wasn't clear enough. The question is...Is the reason the tv has shut down with a constant ACDET log caused by the lack of that signal from the psu to the main board micro, OR the main board micro at fault. Hope this isn't too confusing which is why I really need someone that has had the fault or familiar with LG error logs.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        Re: Lg 42ld560
        which is why you would have to test the psu voltages to confirm there ok,WITHOUT the mainboard,it could be a multitude of problems,i.e the mainboard loading down the psu.
        its called a process of elimination....
        • peterp
          • Jan 2014
          • 7
          • australia
          Re: Lg 42ld560
          I hear what you're saying and I appreciate you taking the time to offer your comments but the question remains the same...exactly what is ACDET referring to?
            Re: Lg 42ld560
            It is the signal the PSU produces to inform the TV that AC power is present and available.
            Without AC power, signal will go away (either low, or high, typically low) and shortly after, PSU outputs will collapse because there is no AC power available.
            The purpose of the signal is to give the main board time to shut down - doing things like muting speakers/headphones to avoid click sound, saving all settings, finishing any writes to memory, etc.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              Re: Lg 42ld560
              im not sure why ac detect comes up,not many may not know either,confuses me.
              if you get an inv_on problem,sometimes you can short it to ground,and restet lamp errors
              ac detect will be coming through the optocouplers,and you can bypass these,to loose the acdetect,and see what comes up in the service menu
              • peterp
                • Jan 2014
                • 7
                • australia
                Re: Lg 42ld560
                Ok , thanks for the input guys. To my mind the psu is most likely causing the issue and due to time restrictions the board is being replaced not repaired. I'll try to update whether it was the right choice or not at a later date hopefully before this thread hits page 10 or beyond. Cheers.
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • semiRocket
                  Toshiba 37bv701b power supply main rails
                  by semiRocket
                  The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                  I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                  Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                  10-26-2025, 01:55 AM
