Samsung UN50KU6300F constant reboot, bad backlights?
    replied
    I hear you, God forbid a gecko gets in the house and starts bumping into the tv. tv gone
  • x_orange90_x
    replied
    I hear that, wish I had a time machine, could go back and just refuse to buy any tv with these damn flimsy easy to crack as an egg shell and ALWAYS prone to shorting panels. They have better resolution and are bigger and lighter than the old crt but not nearly as reliable.
    They keep making the panels thinner too. I feel like my dent pullers are even too much sometimes for these panels. I get that they want TV's to be lighter, but today's 70" tvs only weigh 40lbs at most! At this rate, crazy-flying house flies will be cracking our screens in the near future!
  • bohaboha
    replied
    Originally posted by x_orange90_x
    Here's the clip
    don't see anything on video
    replied
  • x_orange90_x
    replied
    It would be nice if they could all be fixed simply with a component or 2, but unless you work with them a LOT, it can be a real pain to figure out. Just had to retire a good old samsung ccfl from 2007, couldn't figure out the powerboard fault. Could have bought a replacement but had the back off so many times, there was nothing left of the plastic screw receivers to hold the back on and I'm always pretty careful not to over-tighten. Screwing metal into plastic it's so damn easy to strip it out, should stop at the first sign of resistance, beware using power screw drivers. A lot of manufactures have REALLY cheaped out lately, was recently looking at a Hisense 55-Inch Class A6 Series 4K UHD, cheap one board piece of shit, all plastic so the one board has to screw into plastic with a little piece of metal sitting on there, that's suppose to do the grounding I guess, is what they're thinking, shabbiest construction I have seen lately. Wonder if anyone started a thread topic on cheapest made junk they have seen, this hisense fits there. Small wonder I prefer the older tvs that actually use some metal in the construction.
    Wow that one does sound cheap! I cracked a Samsung curved trying to open it because the entire back is screw less. It snaps together all over and it wouldn't let go in one of the corners so the screen fractured.
    A tip that usually works for me with screws is to turn it backwards slowly until you feel it drop in the groove of the thread. It usually makes a slight click sound. Then you know you're in the thread.
    Putting this particular tv back together the other night was a pita because none of the corners wanted to live up with the screw holes. It was like it shrunk while it was off.
    replied
  • vinceroger69
    replied
    Nice to hear you have fixed the tv and another saved from landfill
  • x_orange90_x
    replied
    Glad to hear it, Indeed when you figure all the time that can be spent trying to troubleshoot, if a board is available for a fair price, it sure can be the best way to go, it may also preserve a little sanity, lol.
    Preserve sanity is right! I got pretty pissed at spending ALL that time and it did exactly the same thing. Thank you for all your help and guidance!
    replied
    My guess is the backlight driver IC on the non-working powerboard may be bad, seems like you checked everything else.
    replied
  • x_orange90_x
    replied
    I gave up on diagnosing the original board and just ordered one from eBay. I put it in last night and the tv is working great.
    My advice to anyone else with this model power supply is to just get a replacement. There's too many things that fail on it and getting it working may only buy a little bit of time before another component fails.
  • x_orange90_x
    replied
    It looks like it can't be either of those. 600 M ohms would be a huge resistor, and from what I'm finding .06 ohm doesn't even exist.
    I can't find a schematic for this board either
    Edit: wow this is frustrating. I can't find a schematic, therefore I can't see on paper what the value is supposed to be. Likewise, searching for the board number and "R9022" turns up absolutely nothing. And to top it off I'm finding this exact same model board with a completely different 5 band resistor instead of the 4 band I have.
  • x_orange90_x
    replied
    Originally posted by diif
    Double check the resistor value using one of the many available websites.
    using the tool on DigiKey I get either 600M ohms or .06 ohm depending on the color is the third band, which I'm not positive if it's grey or silver. Can you tell what color it is?
    Also, my reading of 0.00 ohms means my resistor is bad, right?
    Edit: it has to be silver because that's .06 Ohms. Grey would be 600 MegaOhms. I can't however find a .06 Ohms resistor online.
  • diif
    replied
    black, blue, silver, gold is correct. When I looked it up I got 600 M ohms. Maybe I did something wrong
    I checked other resistors on the board and got similar oddball readings. I think the resistor ok. That one diode on the bottom has been mentioned on these forums several times as causing these symptoms. It's surface mount, so if I take it off to test I'd be replacing it as well.
  • x_orange90_x
    replied
    I replaced the diode on the bottom and I STILL have the same symptoms!
    Edit: I removed a leg of that resistor and checked it. It reads 0.00 ohm 😑
    replied
    Maybe there: https://www.aliexpress.us/w/wholesal....home.search.0
  • x_orange90_x
    replied
    Absolutely, I do believe that diode is bad.
    I'm trying to source a replacement right now. I'm going to call a local electronics store later to see if they carry these, but if they don't I'll have to order some. The SK310C I asked about is too far off spec wise. Comparison of those two are attached
    Ir is blank on the datasheet for the SK310C.
    replied
  • x_orange90_x
    replied
    Is it black-blue-silver-gold, I get .06 ohms, if those colors are correct, then even 1.2 ohms is way out of specs, then as usual when a reading seems off in circuit lift a leg and check ooc.
    replied
    09-07-2024, 05:50 AM
  • max789
    Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
    by max789
    Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
    I made the following tests:
    1. Disconnected the main board from Power Board = backlight works.
    2. Connected the main board and disconnected the T-Con = backlights does not work.
    So I ordered a main board from Ebay also BN41-02156A but from...
    01-18-2024, 06:56 AM
  • brkie
    Samsung UE75TU6905 reboot loop
    by brkie
    I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
    I read on Samsung's website (reviews)...
    09-04-2024, 01:45 AM
    09-06-2024, 11:40 PM
