Lexsor LC32W18SD psu
  • Manddave
    • Oct 2013
    • 58
    • Uk
    Hi can anyone help please I'm trying to repair this psu
    All caps have been replaced but no luck yet.
    The tv goes to stand by and there is a slight clicking from the power board
    The board is 782.L32U25-200B V07
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Lexsor LC32W18SD psu
    need a better pic than that,more light
    also what brand of caps did you use and series?
    ticking or clicking sound can be due to shorted secondary diodes or failing startup cap,normally around 50_63v ,47uf-****
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Ah--I know of those hideous PSU's!
      LEXOR used a couple of types in their 32" sets, that one illustrated was the cheapest and nastyest!
      --probably a later series of their set, The earlier supply was a bit of a beast, Dozens of bright orange caps, all dry out, double-sided print as delicate as tissue, and a bugger to work on without damage.
      Check the diodes on the output of the 16 (or is it 17?) and 24V rails, there's two tiny fusible-resistors between the reservoir caps on the 'cold' end of the board after the recs, and between the caps--in series with the supply --should be very low resistance, summit like 0.2 ohm.
      These are in series with the supplies and before the second cap in each rail.
      You can confirm whether they are good by checking the '+' of each of the two caps in each rail for continuity--should have a low reading.
      --Obviously,--there will be no continuity between each rail though....
      A voltage-check across each of the Low-Voltage, (stdby 5, 12, 17, 24V) rail caps will also indicate the condition of the resistors, and also checking the plug headers with 5V input from stby 5v to Ps-on, header-pins via 1k
      (could use the set to turn psu on, but I tend to work on the PSU on its own--much easier to work on....)
      Cheap cruddy caps wont stop those supplies working--They just wont last very long, (talking hours or days) so I doubt that the cap quality is the issue to stop it running. (been there, Done that!)
      From what you describe--the supply isnt 'loaded' and its in 'burst-mode'--hence the ticking/tripping sound....
      --This also points to those series resistors....
      TELEFIX
        by momaka
        03-15-2023, 10:17 PM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
