Sony KDL-46XBR4 and KDL-40XBR4
  • bigtony5858
    • Jan 2014
    • 31
    Can anyone tell me if the I can use a t-con board from the KDL-40XBR4 in a KDL-46xbr4? I found someone that was able to use the 46" in a 52" but I have not found any other information on this :-). My TV is the older version with serial# 80****** I really appreciate all your help!
    Tony
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Sony KDL-46XBR4 and KDL-40XBR4
    ive had success doing this on other tv's,not tried on this model.
    if it looks the same size,same connectors ,give it a try,but you may have to go into the service menu and reset the screen size,ive done this with mainboards as well for different size tv's. more so on main boards.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • bigtony5858
      • Jan 2014
      • 31
      Ok perfect! Have you ever done this on a Sony before? And yes everything matches up and the boards look identical, but no one seems to have any confidence that it would work. I am not sure if it because it is no supposed to work because Sony wants it to be part specific. It should also be noted that this part was sold as part of the panel and there are not alot of them out there because of this.
      Thanks for your help!
      Tony
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        Tony
        i more than likely have,cant remember,im a bugger for not writing down my findings!i must start too lol.
        have a check of the pinouts on the t-con,make sure voltages are the same,and in the right configuration on each t-con,if so,go for it
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
          09-06-2024, 05:30 AM
          Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
          This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
