Question regarding which capacitors to use.
  • lookimback
    • Aug 2013
    • 1489
    I've been fixing TVs for about 4 months now and have always replaced capacitors with Panasonic FC or FM series.
    My question is what other brands/series are suitable?
    ------------signature starts here------------
  • mariushm
    • May 2011
    • 3799
    Re: Question regarding which capacitors to use.
    Low ESR series (High ripple, low impedance), depending where the capacitors are on the boards.
    Panasonic FM, FR,
    Nichicon HM or HN (discontinued), HW (new, 2014), maybe HE and PJ (but check for ripple and impedance first), PW for small uF values (chart here: http://nichicon-us.com/english/produ...ini/pict_f.htm )
    Nippon ChemiCon KZE,KZH, KY, KYA, LXZ, LXY ( chart here: )
    Rubycon ZL, ZLH, ZLJ, ZLK (capacitors chart here: http://www.rubycon.co.jp/en/catalog/...ducts_Eng.html )
    • lookimback
      • Aug 2013
      • 1489
      Thank you!
        After all of...
        07-13-2024, 08:14 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • Green Probe
        Recapping a Denon AVR X6400h SMPS
        by Green Probe
        (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
        Disclaimer: I'm an amateur hobbyist and will get things wrong.
        Always use caution when working around mains power and high voltage capacitors!
        Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
        SYMPTOMS:
        -No display...
        07-18-2025, 03:36 PM
