Vizio VO370M - Amber then white..no response
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I picked up a Vizio VO370M that seems to have a different symptom than others posted here. SO when I plug it in, the light starts amber and then glows white. no flashing. TV has no power, no backlight. So I took the following prelimary measurements. Has anyone else encountered this issue?
    Power Supply Connector CN202
    Pins
    ACO- 0V
    Status - 1.0V
    DCR - .90V
    Vbra - 0.0V
    On/OFF - 0.0
    DM - .05V
    Power Supply Connector CN201
    All the 5V and 12V pinouts are at 5V and 12V as required
    Main Board
    U11 - 7805CT / RAM929G
    Pin 1 12.21V
    Pin 2 - 0V
    Pin 3 - 4.98
    U24 - L352/G1084
    Pin 1 - 2.03V
    Pin 2 - 3.27V
    Pin 3 - 5.02V
  • xeos
    10 year old Vizio VO370M has intermittent flickering backlight
    by xeos
    I have this Vizio VO370M TV that I'd like to save because it has very low input lag (as good as the most expensive TVs sold today!, https://alantechreview.blogspot.com/...input-lag.html), but it has a very annoying issue: sometimes the backlight flickers (or is just kind of dim). The flicker is slower than 60hz, so we aren't just talking some kind of motion compensation).
    I was hoping maybe it was a power board issue (aka failing caps) but I opened it up and I don't see any that look bad. I have a budget capacitance/ESR meter if it's worth checking those...
    05-14-2021, 03:39 PM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • mrtek
    Vizio M65-C1
    by mrtek
    Hi.
    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
    07-14-2025, 07:28 PM
  • triplefour
    Vizio m557-g0 no response
    by triplefour
    yes im still fixing tvs...just not asking for help too often. but i got a puzzler here. tv has no response when plugged in. no standby light, no response to button presses. so i open up to check voltages, and of course thinking i will try to force the PSU on and that will tell me if PSU and BL are ok and most likely that MB is bad. but this tv does not have 5vsb, only 18vsb, so how do i know what kind of voltage to send to PSON and BLON to trick the PSU into turning on without MB? if they still should get 5v, where do i pull that from?
    thanks in advance!
    10-15-2021, 08:34 PM
