I have a tv with these caps but there a bit swollen what can I replace these with as in a better cap for the job thanks
35v 680uf
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
What is your advice/opinion on whether or not on old(er)...-
by GRrHaGHi, I try to replace a VRM Alpha & Omega on a GIGABYTE 3080 TI Eagle,
marking BKU0 but i can't identify part number for buy it
Someone can help me ?
do you know here i can find Sch and brd file for this card ?... -
by jasenpetersEmprex - 26" LCD Monitor - Mfr. Date: May 2008
History:
- Recently purchased from a thrift shop, and went dark after about 2 weeks.
Symptoms:
- Blank black screen, smell of burned component, computers still detect monitor (as Sw26B).
Inspection:
- Took the monitor apart to find a control board and a power board.
- The power board (ILPI-082), near a pair of output leads to the monitor screen, had a visibly burned and ruptured ceramic capacitor, with the following markings:
12J
3KV
JNC
by chth96I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
Since then, This AC/DC adaptor have been out of order.
But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
And Is there any possibility that it will suddenly explode as well as to be out... - Loading...
