The TV kept takinglonger and longer to turn on. Eventually, it didn't turn on at all and the front LED just keeps blinking. I inspected the power supply caps and they didn't appear to be damaged. I replaced six of them with no change. I measured the PS output voltages and they are close. The TV attempts to turn on when plugged in without hitting the front button or using the remote. The ON/OFF signal to the PS was measured at 3.8V. Any ideas? Thanks in advance for your help.
Samsung LN40A630 won't turn on
Re: Samsung LN40A630 won't turn on
You need to locate the startup capacitor {if it has one} on the power supply in the primary section and befor switching the set on try pre heating it gently with a hairdryer. It is a small cap often 50v 47ufPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
I replaced all 11 caps that I bought from shopjimmy. They came as a 'caps replacement kit' for this power supply, bn44-0098a. This change made no difference. One cap was a 0.47 uf, 50v cap that may be in the startup circuit selldoor mentioned. I have the schematic for this ps.
Why would the on/off signal from the main board turn on without me touching the remote or the front switch? If I disconnected the cable from the front switch/ir board from the main board, would anything get damaged? Maybe there is a problem with this front switch board.
I am tempted to just buy a new ps board from eBay for $60. What do you think?
Thanks.Comment
disconnect power buttons and retest,is it buttons on side or touchpanel?
on/off signal should show 0vLast edited by multimeter; 01-19-2014, 11:16 AM.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Comment
The buttons are on the touch panel. The touch panel board connects to another smaller board (IR?) board that connects to the main board.
Should i unplug the cable from the touch panel to ir board?
Maybe there is a fault on the ps board that is pulling up the on/off signal to 3.8v. That is an odd voltage.Comment
3.3v is around rightThe buttons are on the touch panel. The touch panel board connects to another smaller board (IR?) board that connects to the main board.
yes,unplug from the touch panel to ir boardfixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
I unplugged the ir and touch panel boards from the main board. The on/off signal still goes to 3.8v when I plug in the TV. I then tried unplugging the Main board from the ps board. Now the on/off signal stays at 0v. That tells me that the ps isn't pulling this signal high through some ps fault.
Does anyone know where I could find a main board schematic (Bn41-00975c)?Comment
Samsung sometimes include main board schematics in their service manuals. You can try the link in my signature and Elektrotanya.com for service manuals.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I didn't find this (or many) main board schematics online. How close are these main board circuits to one another?
When I push the off button on the remote, sometimes the on/off signal drops to 0 volts (the fan stops running) but then jumps back to 3.8v. If i could isolate the failure to one board or the other, I would decide on buying a replacement board.
Any ideas? ThanksComment
I dont know if this is one of them but I have read that on some power supplies the
on/off pin is high and to switch on it has to be pulled low. I am not sure how to do that
perhaps ground it - Tom/ Multimeter might know?Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
some do pull the standby to ground,not in many though.that i have seen
it sounds like it could be capacitor issues,because of the time it takes to power up.
things to try...
disconnect mainboard ,does that pin stay high?
does the pin that is showing that voltage at the mainboard have low resistance to ground?
what brand and series caps where they replaced with?
heat the psu board for thermal issues,
what voltage is at the startup cap?,though this would give the symptom of ,chirping,fluctuating standby voltages,or dead.
id be heating the startup cap,and output caps,and looking for a change of symptoms.
it could also be EEPROM related,as this chip will use a booting sequence for the tv powering up,maybe worth a check also.using a datasheet for that eeprom,you can check vcc to ground for low resistance,and other problemsfixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
I decided to start replacing boards since my family was asking me to buy a new tv. I bought a power supply from eBay for $60. Replaced it and no change...I then bought a main board from Encompass Distributors for $100. That fixed the problem and everybody is happy. I would rather spend $160 and get my tv back than pay someone a few hundred to repair or buy a new one for $600. Shame on samsung for building such an unreliable product! A TV should last more than 5 years. While this was broken, we were watching my old tube tv that has lasted more than 15 years.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
