Help! Opening my Dell E172fpt 17" lcd
  • dnyce
    • Mar 2007
    I have a Dell have a Dell E172fpt 17" lcd that I would like to repair myself, but I can't seem to open it. There are no screws, other than the four to take the base off. What it's doing is after about 20 seconds, the screen goes blank, power button still shows green, and you can hear what sounds like arcing coming from inside before the screen goes blank. I'm thinking it may be the inverter, but I want to open it to make sure. Any suggestions? Pls help!
    regards
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • Abrith
    dell 5391 blank and topspeed fan, anyone have bios bin file
    by Abrith
    dell 5391 servis tag GJJBJW2. ic type MX25L8006E
    12-07-2024, 07:00 AM
