Panasonic Plasma TV LED blinking 12 times
  • PaulF
    • Jan 2014
    • 17
    • United Kingdom
    My Panasonic TH-50PX70B TV has developed a fault indicated by the red LED blinking 12 times. I have searched the internet and the blinking LED fault codes seem to differ between models. From some comments on this forum I think it is most probably the power board.
    If a can be sure it is this board I would be happy to replace it. it would be even better if I could repair it.
    Does anyone have any more info on this model or can give me some pointers on tests to identify where the problem is.
    Re: Panasonic Plasma TV LED blinking 12 times
    12 blinks is sound SOS. From PX75 manual, a similar TV:
    This can be:
    - bad/damaged speaker (shorted)
    - wiring shorted together, or to frame
    - A board fault
    • PaulF
      • Jan 2014
      • 17
      • United Kingdom
      Thanks for the info Tom66.
      Good job I asked, thought it was the power board.
      I'll investigate and post my findings.
      Much appreciated.
      • PaulF
        • Jan 2014
        • 17
        • United Kingdom
        Following checks on the speakers & wiring I have ordered a replacement 'A' board.
        Are there any adjustments required following fitting of this board? i have most basic test equipment eg. multimeters, oscilloscope etc.
        • EIEIO
          • Jan 2014
          • 6
          Hello Badcaps Forum. I found this board looking for an answer to my "12 Blink" issue on a Panasonic TC-P42S1 plasma. I've read about everything on here and other websites trying to determine if I can fix it for about $200 or so. If not, I'll probably buy new.
          The TV is about 3-4 years old and has had no issues until one day on power down, we heard an additional click after it shut off and immediately the SOS light started flashing.
          Here's what I've checked:
          - unplugged SC board, 12 blinks
          - unplugged SS board, 12 blinks
          - unplugged both SC & SS board, 12 blinks
          - Checked standby and power on voltages coming into A board and all are correct
          - no shorts in speaker wiring or speakers
          - connected speaker to alternate signal source and the speakers function properly.
          By all I've read here and from other sources, it's the A board. However, my A board (TNPH07861A) isn't available many places other than used ones on Ebay with prices from $120-212.
          My questions:
          1. How critical is the board version? I have found TNPH0786AF at ShopJimmy & TNPH07862A versions. (I'm assuming they wouldn't work or can't be changed)
          2. Is there a way to bypass the sound amplifier altogether and just use a sound bar?
          3. Has anyone used ModusLink PTS (http://www.moduslinkptstvboards.com/txn-a1efuus/) for board repair? (This is the direction I'm leaning)
          4. Is there anything else I should do/check before reinstalling a replacement A board?
          Any other suggestions would be appreciated. Thank you in advance!!
          • tw2005
            • Oct 2011
            • 6458
            My questions:
            Little curious about the part number you've quoted TNPH07861A, sounds like the PCB print number.
            What other numbers can you find stamped on the board or a white sticker but not the one on the tuner module?
            A few have had SC boards repaired/refurbed at moduslink, can't remember reading any bad reports.
            • tw2005
              • Oct 2011
              • 6458
              I'd stick to
              TXN/A1EFUUS or TNPH0786 no suffix. There's a matrix on the PCB above the TNPH0786 number. The suffix is determined by the placement of 5 jumpers above that table which you decode looking at the dots labelled in the matrix.
              SJ says yours has no suffix which I suspect means there'll be no jumpers.
              The AF is a 46" panel.
              42U1, version AE I suspect would work however A30 is missing for the fans.
              So it should work as they have the same panel, you won't have fans running.
              That's what I see at a glance.
              • EIEIO
                • Jan 2014
                • 6
                TW2005,
                You are correct that the part number is TXN/A1EFUUS and the board number is TNPH07861A. There is no suffix that I can tell. Pictures are attached of the board numbers I find and the panel info.
                • PaulF
                  • Jan 2014
                  • 17
                  • United Kingdom
                  I've just replaced the A board (2 boards to be exact TNPA4177 and TNPA4226) and the problem is still the same, ie 12 blinks. Any ideas where the problem can be now?
                  • tw2005
                    • Oct 2011
                    • 6458
                    So there is no A-board, but DG(TNPA4226), H (TNPA4177), D (TNPA4133), PA(TNPA4178).
                    Maybe download the service manual
                    See if you can check +15V_S is going to the H board at H3 pins 21-23, delivered from PSU P6 pins 2-4 via PA board, in PA6, out PA3 , in H3
                    H board IC2301 needs Sound15V, Sound12V. Sound12V is generated from the Sound15V(+15V_S) by the voltage regulator IC2303.
                    It appears IC2301 generates the SOS, and a high is operate, a low is SOS so i guess if there was no 15V that would mean a low from that and trip the SOS12.
                    I've got no experience with this generation so I'm just going by the schematic since there's no mention of any voltage checks.
                    It may be the case that you will have to hook up the probes first and then power on to detect the 15V because I expect SOS12 will kill the 15V when tripped.
                    There was another post for similar problem with no result unfortunately.
                    https://www.badcaps.net/forum/showth...hlight=50PX70B
                    Manual shows P or H board as first checkpoints in the blink chart.
                    • PaulF
                      • Jan 2014
                      • 17
                      • United Kingdom
                      Thanks for the reply, yes you are absolutely right about the boards. I'll do the checks you suggested and hope I can trace the board where the fault is. Thanks for the link to the manual, it's a great help, was trying to use a manual for a similar set but had an A board instead of the H & DG boards which is why I replaced them both.
                      If it's the P board I can get a replacement but want to be sure before I go ahead, looks like I've already replaced 2 unnecessarily.
                      Thanks again for taking the trouble to help.
                      • PaulF
                        • Jan 2014
                        • 17
                        • United Kingdom
                        I've done the tests as you suggested and at H3 pins 21-23 & P6 pins 2-4 the voltage only rises to 1.56v max before it is tripped off. Looks like it could be the +15v from the P board? I assume this voltaage is reference to the chassis ground?
                        • PaulF
                          • Jan 2014
                          • 17
                          • United Kingdom
                          Further tests show that I have 15v at TP7 which is upstream of Q351 FET which appears to switch the 15v to P6 pins 1-4. I plan to investigate further at the weekend when I can borrow a probe from work which is small enough to get onto the gate to see if the gate drive is ok.
                          I have not yet been able to identify the FET from it's number NEC 25K2510.
                            Try 2SK2510.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Maybe, how long after the 1.56 does it shutdown? Is it a steady 1.56 or rising when it kills.
                              The other thing I'm looking at is Q2301 and test point TP2301, I suspect gose high on the SOS.
                              I guess what we really need is either to figure a way to test the voltages from the PSU as if the TV was running or I'm thinking if TP2301 if it's high on the trip, earthing that out and see if the TV powers up with no blinks.
                              Then recheck the voltage.
                              There's probably a more correct way, is there anything in the other post that helps.
                              Both H boards are doing the same assuming both are good suggesting the problem is elsewhere.
                              I don't want to say it's the PSU unless it's proven the 15V_S can't be generated.
                              • tw2005
                                • Oct 2011
                                • 6458
                                I was wonder looking at the diagrams, looks like this PSU has those modules (MC351)similar to that in the 46PZ800 and others which had 2 & 10 blink issues generally due to a bad ceramic cap on the module?
                                I believe they were loss of 15V related too.
                                Edit: but then you did say you have 15V, keep digging, hope you find the culprit.
                                  (error on my part, please ignore)
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Don't forget you have the SM. As per Tom's response. Q351 search in the PDF gives you 2SK2510.
                                      There's actually a lot of true part numbers in there unlike the later manuals where they get Panasonic coded numbers which are meaningless most of the time.
                                      • PaulF
                                        • Jan 2014
                                        • 17
                                        • United Kingdom
                                        The voltage increases gradually over a couple of seconds and reaches a max of 1.56v which is steady for probably about a second then shuts off. Will do the test again and take better note of what happens. tw2005 I agree with what you are saying, I'll check out Q2301.
                                        I did identify the FET as 25K2510, I just can't seem to find a data sheet for it to see it's spec in case it is faulty and need to find an equivalent.
                                        Thanks for the help guys.
                                        • ahmarzo
                                          Hp 15-cs laptop 5 times dc jack blinking white
                                          by ahmarzo
                                          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                          12-28-2024, 04:46 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • fourroses73
                                          Panasonic Plasma TX-P46VT20 blinks 10 Times
                                          by fourroses73
                                          Hi all folks.
                                          My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
                                          Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
                                          What i have measured:
                                          Vsus and Vda are ok
                                          Pin1 of connector P7 : 5V ok
                                          Pin1 and 9 of connector P6: 16V in place of 15V but...
                                          12-03-2020, 05:28 PM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
