samsung ps50q96hd picture keeps turning off then turning back on its not psu as repla
  • wreksta
    • Aug 2013
    • 508
    • england
    hi any advice on my problem
    its not psu as replaced that board with know working one I ttried different main av board and does the same after a while
    I checked voltages
    and vs was low so tunned it to the panel spec 207v but when measuring the va my meter tells me its on 15.00and not 65v
    any ideas hope its not y main as have none spare I do however have a load of ldvs boards and z sus boards
  • freakaftr8
    • Oct 2012
    • 3743
    Re: samsung ps50q96hd picture keeps turning off then turning back on its not psu as r
    Check supply voltages with ysus and Zsus disconnected and main still connected. On sustain boards the VA is just passive. Goes directly to x buffers on the bottom of the panel. Hopefully your panel is not shorted loading down the VA circuit.
    • wreksta
      • Aug 2013
      • 508
      • england
      the 50 screen was roasting hot from the rear
      and I could not use pc with screen shutting down so took psu from 50 put in a 42 same model make and the va still down its at 12.5 as I turned it from 15v at the mo with a bad image but no shut downs yet
      so it may be psu then but what loads down va on psu
      now my meter is running low but still measures the vs could be a a low battery problem on meter im going to see how this fares out on the 42 if its fine going to up the va to 15v again so picture gets better
      on a side not say I was getting wrong reading from meter due to battery
      would a high va heat the screen to really BLOODY hot and cause the shutdowns
        Va at 12.5V, are you sure? Maybe you mean Vg?
        • wreksta
          • Aug 2013
          • 508
          • england
          hold on let me check
          edit no mate 12v then I adjust the va adj pot and it will rise to 15 only
          edit tom im a plum or tired yes that's vg but why does va pot rise that voltage
          ill adjust and recheck all
          it came into me like this where pic would go off and you could no longer here the y main buzzing
          then come bk on with picture but tv did not enter standby or click
            I think Va and Vg are on same transformer. Adjusting one causes other to change.
            Be absolutely very careful to set Va exactly to panel sticker.
            The panel would definitely NOT work with a Va of only 15V, it would just be mal discharged (weak, sparkling image) or no image at all apart from glow screen.
            Va is around 50V to 75V.
            If set too high, it's easily possible to kill the plasma panel. So be VERY careful while doing it!!
            • wreksta
              • Aug 2013
              • 508
              • england
              right going to recheck everything and report back had no issues with power board in 42 so far so we will see I may have had the va to high
                09-07-2024, 05:50 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Dodgethis
                Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                by Dodgethis
                Hello all,
                This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                09-11-2024, 07:39 AM
