Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
  • LEECH666
    replied
    I couldn't find any mention of it being LED based anywhere so I assumed it's still CFL based which may be incorrect. Anyway I connected the 1K between +5VS and STBY+BL pins. Here goes nothing.
  • Diah
    replied
    Originally posted by LEECH666
    Thank you again for your help so far. Your short hand style of writing is a bit hard for me to decypher. I assume when you say "if the BL didnt power on" you mean "if the back light (24V to the inverter board on the left and the CFLs) do not power on", is that correct? The rest I think I understand. Anyway time to bust out the soldering iron.
    LOL.... yes BL we used here for back light... and MB to main boards.. yours TV LED one not CFL... so on the web specification
  • LEECH666
    replied
  • Diah
    replied
    so yours PSU Socket i will rename the pins to be more understandable
    5VS = STBY .. STB= Power _ON BL = BL_ON DIM=DIM for BL
    so STBY via 1KR connected to Power_ON & BL_ON ... if the BL didnt power on... you need to add DIM to the same rail of the 1KR.
    PSU will start On. and you will have 12 & 24V... if the buzzing remain... disconnect the BL socket from PSU and check.the noise..
    if PSU & BL power up and No buzzing... keep this mode test... disconnect the LVDS between the MB and T-CON if you have external T-CON.... take from the socket of PSU 12V line and fed the T-CON Fuse F1... check the buzzing... if no more buzzing mean the issue at MB.. i so we do narrow the issue to be sure which part make the overload on PSU
  • LEECH666
    replied
    +5VS seems to be too be the standby supply voltage as it is the only voltage being present after the TV is switched to standby via the remote.
    So if I understood you correctly I should connect the +5VS pin via a 1K resistor to the STBY and BL pin like shown in the attachment?
  • Diah
    replied
    Hi Diah, thanks for your reply. I have to admit that I don't know too much about TV PSUs. I read in the basic TV repair guide that the TV PSU waits for an "ok turn on"-Signal from the logic board. I assume this is the STBY labled pin on the connector that goes to the logic board but how do I get it to power up when the logic board is not connected? The STBY pin measures around 2.9V during operation when everything is connected ... so do I just apply 2.9V to that pin via an externally connected lab supply to turn it on?
    PSU with out Main boards can run as stand alone... disconnect the MB from the PSU socket.. plug in wall messure yours socket you will have only one V STB usually 3-.3V -5V. in yours case i think its 5VS will be... connect via 1KR to in yours case STBY ... and to too BL ( which i think it BL_ON and Dimm... yours PSU will start and power up the BL and you will have on the socket 12V pin & +24V ( this for sound )
    you need to chevk first just plug in wall and the V which exsist will be PSU stand buy V. and the other Pins will be Power_ON ( this will switch 12V & 24V )
  • LEECH666
    replied
  • Diah
    replied
    Buzzing Noise at PSU could be Filter leak.... or Overload to narrow the issue. run the PSU in stand alone test.. if the Buzzing Noise disappear... then the issue not at PSU
  • LEECH666
    replied
    Some scope screenshots attached ...
  • Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but I am not sure if this really is a problem or just a very noisy power supply. I do have professional experience with electronics but I am certainly not a TV repair guy. The output DC voltages from the PSU PCB seem to be fine. So while annoying for the moment I think this might just be severe coil whine and the issue lies with the sound chip or main logic board.
    The audio system seems to be divided into a sound bar (sound projector) that's mounted beneath the screen and a subwoofer module that is mounted to the back shell / housing of the TV.
    When the TV is turned on after being turned off at the power strip level a farting like noise is emitted from the sub module but that goes away shortly after.
    https://www.youtube.com/watch?v=eqRuUCotLAI
    My approach to test the audio was to listen to some music which sound distorted as if the sub speakers are damaged however I testes the subwoofer module on the bench with an external amplifier and the speakers seem to be fine. No damage to the rubber surrounds and tone is fine. No scratching. Coils seem to be able to move freely.
    The next thing I tried was to feed a 20Hz to 20Khz sine sweep (found on youtube) to the system via HDMI3 and it sounds horrible. More like clicking or rattling in the lower frequencies. When the frequency gets higher the sound is more normal for a sine signal.
    I also measure total garbage signals even with a steady 1kHz sine wave on all terminals (headphone out, subwoofer speaker terminals, tweeter speaker terminals) with my new Rigol DHO804 scope.
    Measurements with DMM on the PSU PCB's connector to the logic board:
    +5VS, 5.214V
    GND, 0.01V
    BL, 3.265V
    DIM, 3.290V
    +24V, 23.96V
    STBY, 2.946V
    +12V, 11.899V
    GND, 0.0214V
    Measurements with DMM on the PSU PCB's connector to the backlight inverter board:
    GND, -0.0042V
    +24V, 23.95V
    BL, 3.265V
    DIM, no wire connected
    Some Videos that I've shot with some scope measurements down below.
    Grundig 37 9880 T USB PSU Buzzing Noise
    Grundig 37 9880 T USB Farting Noise
    Grundig 37 9880 T USB 100Hz Sine Garbage at the Headphone Out
    https://www.youtube.com/watch?v=5PlE8wRZYbk
    Grundig 37 9880 T USB 100Hz Sine Measured (at Sub Module)
    https://www.youtube.com/watch?v=_xRJSTvvYiE
    Grundig 37 9880 T USB Thermal 1
    https://www.youtube.com/watch?v=QBh1jmPa3t8
    Grundig 37 9880 T USB Thermal 2
    https://www.youtube.com/watch?v=e62o-2_bwEA
    I suspect that the STV8357FSX sound processor is damaged but I don't know if this could also be some other issue related to the PSU buzzing. Help is much appreciated.
  • maleksa
    Yamaha MOX8 boot freeze and distorted sound
    by maleksa
    My Yamaha MOX8 synthesizer recently developed two issues.
    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
    11-07-2024, 03:28 AM
  • redoxy
    NHT SW10 Subwoofer no sound
    by redoxy
    Unit was working then one day no sound with the unit humming when the power switch is in the off position. When I move the switch to the Auto or ON position, nothing happens, the humming stops but no sign of life (power LED was off). I opened the amplifier and noticed one of the main power 6800uF capacitors was bulging. I replaced both 6800uF capacitors and also replace the large resistors (R41 and R140) since they looked burned. The humming when power switch is in the off position was still present but the unit will power on now. Tried connecting signal to it but then no sound. When I move the...
    06-22-2023, 02:01 PM
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • televizora
    HP 8470p - distorted sound and noise when playing audio
    by televizora
    Hello.
    I have an issue with HP 8470p - rather strange one.
    I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
    Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
    Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
    12-31-2021, 10:25 AM
  • nobbnobb1
    Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
    by nobbnobb1
    I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
    - 1x 3.14 A @ 250V main circuit fuse
    - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
    - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
    11-16-2024, 09:56 PM
