UHD 4K Samsung UE43UN7025 Voltage too high
  • Ricksw
    • Jan 2023
    • 11
    • Portugal
    Hi all.
    Half backlight work fine. 12v in 1 led strip, 2 led strip 178v DC. Two of them are new, 2 led strip blow up .
    Main board bn9649462A. What can be? Same one have this problem too? Anyone have the schematics? Thanks in advance. Regards
  • Ricksw
    • Jan 2023
    • 11
    • Portugal
    • Diah
      • Feb 2013
      • 6601
      yours Title written UE43UN7025 and yours all in one boards said UE43UN7022 !!!!
      • Ricksw
        Ricksw commented
        Editing a comment
        Sorry. You are correct. But on the screen this information appears. But I think the important thing will be the board's reference
    • Ricksw
      • Jan 2023
      • 11
      • Portugal
      Send image
      • Diah
        • Feb 2013
        • 6601
        what written on the back cover ?
        • Ricksw
          • Jan 2023
          • 11
          • Portugal
          Here are a photo. The same.
          • Diah
            • Feb 2013
            • 6601
            edge or direct LED BL? and how many LED unit installed on each strip
            • Ricksw
              • Jan 2023
              • 11
              • Portugal
              This TV have 2 strip led. Can help me with schematics?
              • Diah
                • Feb 2013
                • 6601
                Originally posted by Ricksw
                Hi all.
                LED BL circuit very easy to trouble shooting it with out schismatic. .... yours first post messurments are error...
                you have 2 strips... each had 28 LED type 3030 3V. , 28x3 = 84 V as you have 2 strips 84 x 2 = 168 V if they connected parallel... so where this 12V come.....
                show clear high resolution photo the LED circuit from top and downside of the boards.. include the socket of LED BL from TOP and downside.
                • Ricksw
                  • Jan 2023
                  • 11
                  • Portugal
                  Hi Diah. Thank you for your attention. Same Samsung TVs I've repaired: FHD, HD ready and now UHD, I don't remember finding one like this, melted along the led strip. In confidence, I put the new led strips, the same strip popped again. I'll go back to see the values and then I'll come back and give you news. This TV was repair in guarantee time, same problem. When it was repaired I don't know if they changed the board. Thanks
                  • Diah
                    • Feb 2013
                    • 6601
                    who knows.... many things are mistrust for me.. i would suggest don't buy ready strips,,, just buy Led from aleexpress 3030 cool white 6000 3.3V --. 100 pieces will coast less 6§... replace all on yours in hand burned strips..
                    • Ricksw
                      • Jan 2023
                      • 11
                      • Portugal
                      God idea. Going to do that. Thanks
                      • Diah
                        • Feb 2013
                        • 6601
                        from the photo of the strips they look to me double so ine LED may 6V... check before order
                        • Ricksw
                          • Jan 2023
                          • 11
                          • Portugal
                          Hi. This TV has two LED strips. When everything is ok in terms of the LED and the power cable is connected, they both light up. In this case I found it strange that it didn't happen. I had to connect the infrared cable to make it turn on. A one strip of LEDs turned on and flashed 4 times on the infrared receiver. I immediately saw that there were more problems. I'll see if I can read the no-load voltage value and then divide it by the LEDs and find out its value. I hope you let me read the empty tension.
                            09-07-2024, 05:50 AM
                          • DynaxSC
                            Extreme High Current & Low Voltage Short Killer ??
                            by DynaxSC
                            Hi Folks
                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                            After taking off the socket, the shorts dissappear again.
                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                            10-15-2024, 10:13 AM
                          • SoporteHR
                            LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
                            by SoporteHR
                            Greetings to all, I hope you are well.
                            I consult you because I have a problem with this power source.
                            The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
                            When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
                            I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
                            but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
                            06-20-2023, 04:30 AM
                          • harp
                            high voltage high resistance marking resistor
                            by harp
                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                            08-26-2024, 01:42 PM
