LG OLED55A1PUA
  • lotas
    • Jan 2016
    • 4900
    • Russia
    #61
    Originally posted by Diah
    this related to ThinQ AI.. funktion
    instead of NOR / Sspi they used this.. if you get it out from the circuit you will see howmany pins are used 12-16 only... how it come eMMC work with just view PINS
    All necessary contacts are used, as with all eMMCs.
    • Diah
      • Feb 2013
      • 6614
      as you wish & like.... i am wrong.chesrs
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        #63
        Repair-it, can you tell me the marking of the emmc? My supposition is that oled screen stores a vcom value for each subpixel, that means for a supposing 12bit data needs at least 37mB, the most large spi i usually see is the 128mbit that holds only 25mb, and plus needs to store the complex fpga programming.. since the main chip is a SoC+fpga and not only fpga like lcd, i guess it stores also a dedicated linux operating system, in.fact there is also uart port for debugging.. the oled tcon are much different from lcd ones as it seems, every one can notice the presence also of huge ram, when in lcd is totally absent, ram means software presence...it maybe integrates also frc function.. the pixels voltages are similar, same vdd, hvdd, vgh, vgl
        • repair-it
          • Nov 2020
          • 116
          • US
          #64
          i don't know from where you got this wrong INFO about OLED T-CON ? there are NO eMMC on T-CON at all...
          The attached picture shows the eMMc chip on my T-CON board, just to clarify your inaccurate statement. Click image for larger version
ID:	3203243 What I hope to do is find a way to test the eMMc chip and maybe even learn how to clone a good eMMc.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4543
            • Italy - Milan
            #65
            why don't you start with the easyest things? Reflowing the ram chips / emmc..
            • Diah
              • Feb 2013
              • 6614
              with yours replacement Main boards... every things plugged in... only the 24V socket disconnect from T-con side.... plug it in wall... if it turn on and the optic lit red... send IN_STOP followed with 0413 with service RC. it will turn off to STBY state.. this will resetl rest this chip and the main one on MB
              • repair-it
                • Nov 2020
                • 116
                • US
                #67
                I have already tried that, there was no response from the TV. At this point I am giving the TV back to customer as he does not want to try replacing the T-con board and I have already spent way too much time trying to figure this one out. Thank you to all who offered their suggestions.
                • Diah
                  • Feb 2013
                  • 6614
                  you do it before with original main boards..... i wrote to do it with replacement one which you get sound.
                  • repair-it
                    • Nov 2020
                    • 116
                    • US
                    #69
                    ok, will try that as you suggest, one last time 👍😖
                    • repair-it
                      • Nov 2020
                      • 116
                      • US
                      #70
                      ok, Heard relay click when I pressed '0' and agin when I pressed '3'. LED remained on. What should I expect after hearing the relay click? Should I reconnect cable & try to power on?
                      • Diah
                        • Feb 2013
                        • 6614
                        maybe yours service remote send IN_STOP complete command ( mean no need to 0413 ) any way.. if its went to stand by after the command,,,, leave it discharge connect the socket back and try keep your eyes on the screen
                        • Diah
                          • Feb 2013
                          • 6614
                          BTW: at this test after disconnection the 24V socket and its turn on and optic lit red...... mean yours T-CON fine,,
                          • repair-it
                            • Nov 2020
                            • 116
                            • US
                            #73
                            ok, thanks for all the help. I tried to power on & all I got was a relay click. I tried using both the service remote and the button on the TV. The LED blinked momentarily but nothing came up and now no longer get the chime either. Giving set back to customer, my guess is panel went bad.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4543
                              • Italy - Milan
                              #74
                              • repair-it
                                • Nov 2020
                                • 116
                                • US
                                #75
                                I just got another OLED, didn't want to take it but they asked if I could 'at least look at it.' Will start a new post for that tv which is a SONY BRAVIA OLED XR-77A80J
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4543
                                  • Italy - Milan
                                  #76
                                  I guess it has the same LG brand Screen, and same problems.. my guess is the same as ever with LG displays.. bad solder.. needs solderings back to youth.. are you able? have you asked the spending threshold? Preparing for a repl. TCON.. and maybe pairing+recalibration costs / headhaches?? And if is main board? Sony famous for bad software, all withing EMMC..!! If i would be you i think better before handling a 77 monster..
                                  • repair-it
                                    • Nov 2020
                                    • 116
                                    • US
                                    #77
                                    Yes I am second guessing my choice. I have a small place and this one is testing my space limits. Trying it just this one time, I think I will stay away from anything larger than 65" and from OLED completely unless am able to become more proficient (more studying) at troubleshooting them. The LED TV's seemed much easier by comparison. BUT, maybe it's just me.🤔 Customer is coming today to p/u his LG. He said he will try to resolve it with LG direct (good luck with that!) I gave it my best shot but it got to a point it was no longer worth my time & there were other device repairs I needed to get done.
                                    • MASTER_TECH_101
                                      • May 2018
                                      • 12
                                      I see you guys turning every discussion about OLED TVs in rocket science.
                                      Here is ELI5 tutorial.
                                      LG OLED
                                      Unplug LVDS cables between main and Tcon, set turns on? Have a sound? If yes then Tcon/panel bad. Trash it.
                                      You can play around by shortening Tcon sys_pow_off pin #40 on LVDS 51 pin connector on main board side.
                                      That will force main to turn on and you would have all voltages present on Main board and Tcon as well. Your panel might lit up with lines or blotches.
                                      You can also unplug 4 wide ribbons between Tcon and panel and check voltages or scope driver waveforms if you have high end oscilloscope and know what is to be seen on VBY1 lines.
                                      Sony OLED
                                      If you can't get set to turn on, in 90% of the time you would have bad Main board. Rest of 10% would be PS module.
                                      If you unplug LVDS cables TV will go into shutdown with 4 or 5 red blinks, and UNLIKE LG, YOU WILL NOT HAVE ALL VOLTAGES PRESENT!
                                      Also, bad panel would give you 4 or 5 red blinks.
                                      No blinks, present 3.3V Stby and 12V run, 1.8V and 3.3V on EMMC, bad Main.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4543
                                        • Italy - Milan
                                        #79
                                        Who is the maker of these tutorials? If he is the manufacturer then is not a valid source.. today SM are not the bible..! Another LG OLED in a forum is been saved by replacing tcon.. bad tcon is not=TV demolited...
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          Gigabyte AERO 14 OLED BMF-72DEBB4SO Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72DEBB4SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72DEBB4SO boardview and 14 OLED BMF-72DEBB4SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
