samsung hpt 5054xxaa
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    Have all boards in except. upper buffer board. i have tested with dmm and have all the right numbers but the screen will flash on for a split second when powered on..with a bottom. half has like multi colors blue green red and white. and its distorted.
    Could this be a bad main logic board ? I have a green light on logic board and y main . my camera is broke or i would post some pictures.
    Buffers are new ..and y main is new
    thanks for any tips /help
    Re: samsung hpt 5054xxaa
    You got both buffers in? Could be -Vsc or Vsch voltage fault.
    • tocold4u2
      • Dec 2012
      • 284
      • usa
      No i just have lower buffer hooked up.
        That can happen with a working Y-main and lower buffer if the lower buffer is missing the drive signals that would normally be fed in via the upper buffer.
        • tocold4u2
          • Dec 2012
          • 284
          • usa
          No just lower buffer is in. i have no response from powebutton on side of tv.
          If i unhook the buffer board n leave the set run without lower buffer .
            So panel only lights briefly? Does a small light illuminate on Y-main, near the white ribbon cable?
            • tocold4u2
              • Dec 2012
              • 284
              • usa
              Yes the sm light on y main lights up....i just had both buffers in but didnt have the tabs on the upper buffer. when i powered the set on. the two color band resisters on left side of. on y main started to glowing red hot so i killed power to the set
              • tocold4u2
                • Dec 2012
                • 284
                • usa
                Im suprised i didnt blow a hole in buffer chip
                  I think you might only have a bad Y-upper buffer if light doesn't light up and you get continuous video noise on bottom half, but if the noise is dropping out you could still have a fault on the Y-main.
                  • tocold4u2
                    • Dec 2012
                    • 284
                    • usa
                    Those 2 resisters shouldnt get red hott...i bet there is a fault on y main it was right where the upper n lower buffers boards come together at. y main
                      I thought with only bottom in it was working? I am confused now.
                      • tocold4u2
                        • Dec 2012
                        • 284
                        • usa
                        With just the bottom one. hooked up..the pic. comes on for a split second when i powdr the tv up !. i then tried. the lower n upper buffer. but didnt have the tsps from panel. on upper buffer board.. n thats when those two resisters got red hot
                        • jettboat
                          • Nov 2012
                          • 63
                          The light on the y sus is a fault. remove buffers & check the ysc voltage should be -190 if I remember right. a +v will blow up good buffers quickly, had one of these the transformer was bad caused it. I have 4 of these boards usually easy fix but finding cheap buffers on a 720 tough
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            Ok thanks..i thought that livht ment you had proper voltages.
                            • splitcrete
                              • Dec 2012
                              • 387
                              • usa
                              I fixed 3 of those sets ,and all the same .Bad upper buffer ICs,Y-main mosfits. If you have a green led on your Y-Main you have a fault on Y-Main. I'm looking for my notes on that model when I find them I will post info. Oh all three when fixed had no (power off) on side of the set. The one in front worked so I didn't look for a problem with it.
                              • tocold4u2
                                • Dec 2012
                                • 284
                                • usa
                                i will check the y main for. bad mosfit..with the lower buffer taken off there is no green light on the y main
                                • tocold4u2
                                  • Dec 2012
                                  • 284
                                  • usa
                                  What would a bad mosfit measure ?? i think i may have 2
                                  • tocold4u2
                                    • Dec 2012
                                    • 284
                                    • usa
                                    didn t find any
                                    • tocold4u2
                                      • Dec 2012
                                      • 284
                                      • usa
                                      couldnt find any shorts ..but but lower buffer in the bottom half of screen has blk bar
                                        Looks like top half isn't sending signals to bottom half == bad top buffer board possibly.
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Yanleb
                                          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                          by Yanleb
                                          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                          If they are not compatible why did Samsung give them the same part number to begin with?
                                          08-04-2025, 11:35 PM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
