Troubleshooting Vestel TV, has standby, but cannot turn ON
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
    Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
    Both boards are shown in the attached photos.
    What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes) for short. Everything seems fine. There are no bulged caps visually.
    In these cases, what is more probable, for problem to be on power board or the mainboard?
    Any advice is greatly appreciated.
  • vinceroger69
    • Mar 2012
    • 6714
    maybe a firmware issue what lcd screen is used in this set its usually printed on a white sticker on the metal chassis
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Ok, I will check and get back with the required info.
      • Adenitz
        • Jan 2021
        • 122
        • Congo
        Here are the info I could find:
        Hitachi model: 32HYC01, manufactured date: 1510
        On the white sticker on the metal chassis I see: Model: VES315WNDB-2D-NO2
        There is also the following information on the PCB board HV320WXC-200_X-PCB-x0.0, HV320WHB​
        • lotas
          • Jan 2016
          • 4598
          • Russia
          Do you even have a programmer to program spi flash?
          • Adenitz
            • Jan 2021
            • 122
            • Congo
            I do have ch341a and I used it few times to read and write BIOS dump files but only in laptops. Never used anything like that in TVs.
            Why do you thik it is firmware issue? Are there some things I can check with multimeter to be sure that hw components are okay?
            • vinceroger69
              • Mar 2012
              • 6714
              Hi i missread your first post i thought you had tried your power supply in another set and it was fine after re reading the first post i now notice its the remote control you have tried on another tv and the remote is fine so yes we need to rule out the power supply first by checking all the voltages etc. The only reason i mentioned firmware was the mainboards do suffer from issues but thats usually indicated by a flashing standy led yours is solid red.
              • Adenitz
                • Jan 2021
                • 122
                • Congo
                Thank you vinceroger69, after reading your reply, I decided to change electrolytic caps on low voltage side even though there were no visible bulges or any deformity. I have replaced 35V, 25V and 16V caps and it indeed solved the issue.
                Thank you for your reply, it indeed pointed me into right direction.
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • PNI E.
                  Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                  by PNI E.
                  Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                  03-17-2025, 04:23 AM
                • madsox
                  Harman Kardon AVR 171S - standby led lights up, does not turn on
                  by madsox
                  Greetings!
                  Thank you in advance for your understanding, I am writing to you through a translator.
                  A Harman Kardon AVR171S amplifier was given.
                  The history of the machine is as follows:
                  It was faulty when I bought it, I want to fix it.
                  I replaced the HDMI switch and one of the DAC ICs in it.
                  After that it worked without a problem.
                  I watched a movie using the amplifier, and at the end the amplifier got really hot.
                  The cooling was faulty, I will fix this later.
                  I switched it to standby mode, waited for...
                  09-24-2022, 10:46 AM
                • cruiser_
                  Vestel 17IPS71 + 17MB82S - no standby
                  by cruiser_
                  hello there,
                  I am trying to fix a Walker 40 TV - it has Vestel 17IPS71 3R3 as PSU and 17MB82S for logic.
                  How I got here...
                  The TV had shorted USB connector, which I fixed. TV turned on. Ran for a few hours on HDMI input. Started to see some dark dots/patterns on the screen as seen on the photo.
                  I restored to factory setting. The TV has rebooted only to a blinking standby LED. It sat there for a number of minutes after which I disconnected it.
                  Now, after plugging it back in - there is not even a standby LED.
                  My 17IPS71 provides 12V, no standby...
                  11-25-2021, 12:48 PM
                • pajdek
                  Lenovo Y700-17ISK turn on and off
                  by pajdek
                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                  09-20-2023, 02:49 AM
