when a panel driver ic goes horribly wrong. ..
  • freakaftr8
    • Oct 2012
    • 3743
    Samsung 52 inch lcd panel tape carrier ic goes into thermal short and melts itself into the plastic panel frame. Lol.
    http://i845.photobucket.com/albums/a...psec7e9930.jpg
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: when a panel driver ic goes horribly wrong. ..
    *runaway
    Follow the white rabbit.
    • freakaftr8
      • Oct 2012
      • 3743
      Needless to say at least it can still be watched behing the freakishly wide colorful stripe
        Mind sharing model # of set? Curious how new it is... So many new LED-LCD and LCD TVs with driver chip faults.
        • mmartell
          • Oct 2013
          • 3189
          I'm sure there's a very good reason those ic's are on the ribbon instead of a few inches the other way and on the driver board with proper thermal treatment but I can't fathom it.
            1920x1080p display, 5760 sub pixels (1920 RGB), 10 ribbons, you need 576 bond wires per ribbon. At 0.1mm spacing on PCB (generally a minimum) you need 56 mm per panel driver, plus other pins. Not really practical; quite expensive.
            • mmartell
              • Oct 2013
              • 3189
              I knew there had to be a good reason
              Why can they manage on ribbon and not on pcb ?
                I think it's because ribbons are a lot smaller so it's easier to manufacture them to tight tolerances, a large panel PCB on the other hand is a lot more difficult.
                I saw a 52" Sharp which looked like it had the PCB->tab bonds replaced with locking ribbon connectors. I liked that a lot, but I'm sure it's a lot more expensive. The chips were still on ribbons.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Ln52a550. 2009 I believe.
                    2008 model. They usually have tab bond issues rather than panel faults...
                    • howardc64
                      LG 49UJ6500 LCD panel lighter band that goes away
                      by howardc64
                      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                      02-19-2023, 12:13 AM
                    • triplefour
                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                      by triplefour
                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                      tcon is built into mainboard.
                      Only one cable goes to panel boards.
                      there is a cable from one panel board to the other that links them.
                      cost cutting measure that results in us having harder time to diagnose.
                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                      07-28-2022, 07:59 PM
                    • Storyteller12
                      QN55Q60R Service Menu Panel Help
                      by Storyteller12
                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                      01-13-2024, 01:57 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
