Schematic of a PHILIPS 50" TVC
  • Ahakim
    • Apr 2013
    • 64
    I would appreciate to put my hands on a schematic of a 50" Philips TVC:
    I read on back cover:
    Philips SLC7 .2E PA
    Model: N° 50PFP5532D/12
    manufactured in Hungary.
    Symptoms: Sound normal, No light (threfore no picture). TV on: oder and smoke from these 2 R's:
    R5600 and R5610 both almost completely burnt (open). I conldn't read the values...What could be the original fault?
    I couldn't find this one in the lists on this forum.
    THANKS...
    Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic
    Philips TV Power Supply LED Driver MSD3463-T8C2 Schematic...
    11-06-2024, 03:47 AM
  • Hillybilly
    philips HTS3530/05 sound system Schematic
    by Hillybilly
    Hi I've been trying to test for a fault on a pcb code 40-S351OA-PWB1G and ha ving tested a certain component with multimeter and atlas dca55 which came up with faulty component also the multimeter set to a diode mode couldn't get a reading.on board i'ts zd501,could anyone tell me if this component would make the pcb drop 42v which supplies to amp side of philips HTS3530/05 sound system please.A schematic with codes for parts would be much appreciated.Thanks
    07-24-2023, 08:13 AM
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • atunguyd
    Acer x163w Monitor PSU schematic
    by atunguyd
    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
    03-05-2025, 02:08 PM
  • Adv10119
    Need help please! schematic for LA-9982P rev 3.0 (A02)
    by Adv10119
    Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
    I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
    I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
    01-31-2024, 01:18 AM
