LG 50PA4500 plasma thin black vertical lines
  • Shifty
    • Dec 2013
    • 10
    A friend dropped her one year old tv off on my workbench, I've never diagnosed a plasma before and it seems like I'm the first to tear down this model.
    Dark or shined stuff appears green while bright and whites appear pink, there're evenly spaced thin black vertical lines, every second line is less pronounced. I'll let my picture explain the rest, please help!
    Re: LG 50PA4500 plasma thin black vertical lines
    Apparently usually just a loose LVDS cable between main board and control board on these models, at least that applies to 42".
    • Shifty
      • Dec 2013
      • 10
      Thanks for the tip, simply removing that cable and replacing it changed nothing. I will get some cleaner and start checking all connections. If anyone has another idea I'll be here working, your input is valued.
        Can you post a picture of the control board? It's a green board, about in the middle, connecting to the main input board and the sustain boards, among others.
        • Shifty
          • Dec 2013
          • 10
          here it is
            OK, do you see the two holes in the board, and just below, a marking "EXT_AUTO_GEN"? Place a wire jumper between the holes, and unplug the LVDS cable. You should get test patterns on the display when the TV is powered up.
            • Shifty
              • Dec 2013
              • 10
              okay i did that, got some patterns going now.
                Are the patterns clear or distorted?
                • Shifty
                  • Dec 2013
                  • 10
                  the thin black vertical lines are present through the test patterns, I'm not sure of what they're suppose to look like.
                  The first two moving patterns are definitely distorted.
                  • Shifty
                    • Dec 2013
                    • 10
                    https://www.youtube.com/watch?v=LCnfkr3TlOw
                    here's a tube of the test screens
                    the only one that looks close to normal is the descending horizontal white bar
                      This confirms the control/logic board is bad.
                      Should look like:
                      http://www.youtube.com/watch?v=xgrvRc2JVVQ
                      • Shifty
                        • Dec 2013
                        • 10
                        Is there any chance that flashing the board will correct the problem?
                          Well, you can try it, but I see these boards as being available from as little as $12:
                          http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                          So I'd just put $12 in it and try it.
                          • Shifty
                            • Dec 2013
                            • 10
                            Thanks a bunch,
                            It's was $40 shipped from USA, I could have got it from a less reputable seller, I didn't need to expedite the international shipping or get the 180 day warranty but it's for a friend. I'll update this thread when I have some results!
                            • sspoonmann
                              • Mar 2012
                              • 12
                              • king
                              well did it solve it?
                              • Stanley1843
                                by Stanley1843
                                06-29-2024, 11:54 AM
                              • polaro
                                Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                by polaro
                                Greetings,
                                I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                08-27-2022, 08:46 AM
                                HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                                This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                09-06-2024, 06:50 AM
                              • afex
                                Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                by afex
                                This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                I have attached an image of the TV with these bars displaying....
                                11-08-2021, 09:23 PM
                              • Falki
                                Colorful LCD Vertical Lines on Samsung ue55es8090
                                by Falki
                                Hello there, ive recently found an older 55inch Samsung SmartTV.
                                A similar issue has been posted as well but also with no actual response ...
                                08-12-2025, 04:19 AM
