LG 50PA4500 plasma thin black vertical lines
    A friend dropped her one year old tv off on my workbench, I've never diagnosed a plasma before and it seems like I'm the first to tear down this model.
    Dark or shined stuff appears green while bright and whites appear pink, there're evenly spaced thin black vertical lines, every second line is less pronounced. I'll let my picture explain the rest, please help!
    Re: LG 50PA4500 plasma thin black vertical lines
    Apparently usually just a loose LVDS cable between main board and control board on these models, at least that applies to 42".
      Thanks for the tip, simply removing that cable and replacing it changed nothing. I will get some cleaner and start checking all connections. If anyone has another idea I'll be here working, your input is valued.
        Can you post a picture of the control board? It's a green board, about in the middle, connecting to the main input board and the sustain boards, among others.
          here it is
            OK, do you see the two holes in the board, and just below, a marking "EXT_AUTO_GEN"? Place a wire jumper between the holes, and unplug the LVDS cable. You should get test patterns on the display when the TV is powered up.
              okay i did that, got some patterns going now.
                Are the patterns clear or distorted?
                  the thin black vertical lines are present through the test patterns, I'm not sure of what they're suppose to look like.
                  The first two moving patterns are definitely distorted.
                    https://www.youtube.com/watch?v=LCnfkr3TlOw
                    here's a tube of the test screens
                    the only one that looks close to normal is the descending horizontal white bar
                      This confirms the control/logic board is bad.
                      Should look like:
                      http://www.youtube.com/watch?v=xgrvRc2JVVQ
                        Is there any chance that flashing the board will correct the problem?
                          Well, you can try it, but I see these boards as being available from as little as $12:
                          http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                          So I'd just put $12 in it and try it.
                            Thanks a bunch,
                            It's was $40 shipped from USA, I could have got it from a less reputable seller, I didn't need to expedite the international shipping or get the 180 day warranty but it's for a friend. I'll update this thread when I have some results!
                              well did it solve it?
