2011 rca 46la55r120q led tv - backlight works, no picture, no sound
  • kburks1230
    • Mar 2010
    • 87
    Re: 2011 rca 46la55r120q led tv - backlight works, no picture, no sound
    Originally posted by tom66
    Hmm, yeah, I looked closely at that board again and the power for the t-con passes straight through the board. Not sure what else to suggest; looks like your main board is bad.
    I replaced the main board, now I have 12v on the 4 red wires where there was no voltage before. I also replaced the TCON board and still have something like .3v on the fuse on the TCON board. What the heck?
    I still have the same problem, no pic or sound...
      Could be a broken connector or wire assembly?
      • kburks1230
        • Mar 2010
        • 87
        What about this board:
        This board goes between the main board and the TCON board:
        DIGITAL BOARD RE3342B051-C1
          Can we get a pic of it? Could be motion FRC for 120Hz picture.
          • lalin
            M
            • Apr 2015
            • 20
            • us
            Is this the best way to know the logic board is working, to test the voltages coming out of it? thanks
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • ex250
              Kenwood SW-505D no sound issue and pops from time to time when it works
              by ex250
              Hello mates,
              I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
              It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
              12-29-2024, 03:27 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
