Panasonic DMR-EX77 with H19 fan fault (unit shuts off)
  • quattro alex
    • Mar 2012
    • 92
    This is a Panasonic DVD & PVR combo that starts up and then shuts off after 30secs or so.
    I got the device into service mode and this highlighted an H19 fault ( this relates to the case fan). The was not moving at all, and on closer inspection I found some polystyrene trapped in there. This was removed but the fan did not operate still, I disconnected fan from connection P7502 and tested on 9v battery and this worked fine.
    I believe the fan getting stuck might have caused an over current issue at the fan motor transistors Q7505 an Q7511.
    Questions:
    1. Does that scenario sound likely?
    2. Would a diode test confirm whether these are good/bad, if so is it positive on the single leg and probe the other 2?
    Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
    Re: Panasonic DMR-EX77 with H19 fan fault (unit shuts off)
    What voltage do you get at FANOUT? What about at the 12.4V rail?
    For Q7511 to turn on, the base-emitter voltage must exceed approx -0.6V (i.e. more negative.) For this to happen then the base voltage relative to ground should be less than about 11.8V.
    Q7511 is controlled by Q7505, which pulls the base of Q7511 low. For this to happen Q7505 must receive a signal through R7660.
    • quattro alex
      • Mar 2012
      • 92
      I have 0v from the FANOUT
      I have checked resistance values for R7660, R7574, R7540, R7583, R7539, R7538, R7525, R7571 and R7538 they're all correct.
      I can confirm continuity between R7660 and Q7505 (bottom left leg)
      Will I be able to test those voltages without the other boards connected?
        I don't know if you can check without all boards connected but there's nothing stopping you soldering colour coded wires to the places I indicated.
        • quattro alex
          • Mar 2012
          • 92
          Just to confirm I'll be soldering 2 leads, one onto the base and one onto the emitter of Q7511 and then negative lead of DMM will go to ground and the positive will be connected onto the other lead (take reading) , then the swap with the remaining lead?
          Thank you for your suggestions.
            I would also do base of Q7505. But yes like that.
            • quattro alex
              • Mar 2012
              • 92
              Base on Q7505 is 0v on standby and when the unit is switched on
              Base on Q7511 is 12.27v standby and on, but after 2 mins this drops to 11.62v and 30secs later the device powers down (standby) and the voltage goes back to 12.27v
              Emitter on Q7511 is 12.30v standby and 12.27v when on.
              Does this confirm an issue with Q7505 or is it further up the line?
                Q5705 is not receiving a signal. Check C7587 is not shorted and R7660 is approx 10k. Trace back signal from R7660. Try checking voltage on other end of R7660, away from base of transistor.
                • itacipri
                  • Nov 2015
                  • 3
                  • Brazil
                  Hello quattro alex.
                  Did you get the fix done?
                  What did you do?
                  • APOPAP
                    Panasonic National NV-M3 VHS Camera shuts down after some seconds
                    by APOPAP
                    Hello everybody,
                    First post here. I have been reading posts here for some time now, but today I made my first account and post.
                    The same question is also posted on another site, here it is:
                    Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                    I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                    08-25-2025, 10:12 AM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • PowellSkier
                    Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                    by PowellSkier
                    A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                    06-17-2024, 11:43 AM
                  • Rictech
                    Panasonic SA-MAX770PU SMPSU board fault....
                    by Rictech
                    Hello everyone. πŸ˜€
                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                    There are no devices that have exploded or otherwise show signs...
                    08-26-2024, 01:05 AM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                    11-20-2024, 08:52 PM
