LG 50PC55 Plasma Vertical Bars!
    Re: LG 50PC55 Plasma Vertical Bars!
    It could easily cause the symptoms. "No signal" is not the fault. It is just because no input is connected.
    • studfish
      • Dec 2013
      • 23
      • uk
      Hi Tom thanks but even when i have devices connected and change the input using the controls on the tv i still get no signal.......... main board?
      Also if i press the menu button the tv turns off .
      The Red standby light does not change either it just goes from red to off
      • studfish
        • Dec 2013
        • 23
        • uk
        just as an update......
        I changed the mainboard and now the standby light turns from red to green so there must have been some kind of problem with the original.... all other problems remain however
          Could just be different config/software on main board. Doubt main board was bad. 99% Y-buffer, 1% Y-sustain (if -Vy or Vsc askew.)
          • Glitcher
            • Mar 2013
            • 673
            • USa
            Common problem would be a blown IC on one of the buffer boards. Just a guess but it is a FQB46N15? If it is then replacing it should fix the problem.
            • studfish
              • Dec 2013
              • 23
              • uk
              #26
              gone over the power supply with a fine tooth comb and found a bulged 250v 820uf cap (dont ask how i missed it) guess that need replacing before i go any further
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                #27
                IF you have Vertical bars on the pic, then there's a high chance the Address Chip associated with that area of the screen is stuffed.
                These chips are found along the Bottom edge of the screen and are often part to the flexible connection to the screen--and are part of the screen and not replaceable.
                --If so, then you'll need a new plasma panel......
                The dead/int dead could well be a protection system coming in due to the stuffed chip....
                TELEFIX
                • studfish
                  • Dec 2013
                  • 23
                  • uk
                  #28
                  Im still after getting this tv repaired so i have uploaded a short video of the problem I would appreciate it if someone could tae the time to have a look
                  Kev
                  • studfish
                    • Dec 2013
                    • 23
                    • uk
                    #29
                    Ive just checked the va and vs voltages and wondered if there within tollerance?
                    The va is suppose to be 60 but is reading 55.2
                    The vs is suppose to be 190 and is reading 188.6
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      #30
                      One of your Y-Buffers are bad... You need to replace the blown FET IC on it.
                      If you find that after replacing the FET, the problem is still there, you need to check it again as it may have blown again.
                      Its a common problem and usually the FET will blow again if your Y-Sustain is starting to go bad.
                      • studfish
                        • Dec 2013
                        • 23
                        • uk
                        #31
                        Thanks the top y-buffer is bad so ive done the va vs test with them dissconected would this make a difference?
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          #32
                          I don't think the VA or VS voltages would change whether or not the buffers are disconnected.
                          • JesusJones
                            Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
                            by JesusJones
                            Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
                            The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
                            04-13-2021, 01:45 PM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • LanTHrusteR
                            SAMSUNG PLASMA TV PS51E550D 1W shorted BDXXX on board
                            by LanTHrusteR
                            SAMSUNG TV PS51E550D 1W,
                            Symptoms: the panel is on but no picture, fuzzy color vertical lines at the black background at both sides of the panel. Very similar to this:
                            Disconnecting left side of the panel fixed the right side which went on and displayed picture although with vertical black bars coming from the middle X-BUFFER panel at the bottom of TV and the same 1 fuzzy color vertical line ~ 0.11 inches long and a few 1 pixel black bars. The disconnected left side showed fuzzy colorful bars, may be some glimpses of the the correct image from menu at the right side...
                            07-13-2022, 06:47 AM
                          • x_orange90_x
                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                            by x_orange90_x
                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                            09-04-2023, 12:09 PM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
