Help troubleshooting my Samsung Plasma TV FPT5084 PSU (BN44-00175A)
  • Zragnarok
    • Nov 2013
    • 9
    I have a plasma TV, a Samsung FPT5084 with the power supply #BN44-00175A and i'm having the common bad cap problem... I think I can say for sure that my problem is on the power supply because I have a fuse always blowing on it. At first, I replaced the fuse and my TV was back to normal. But after a second time I changed the fuse in a month, I searched for another problem. I replaced a few caps (only the one that I saw were bulged at the top) because at that time, I thought it was the only sign of a bad cap. The fuse kept blowing so I bought a power supply from BUYQUAL. When I put it in, I get a different problem (TV turn on and is fine for 2 min and then turn off and I get the blinking red LED in front). So here I am, looking for some help :/
    1. I should have asked before buying but anyone know if BUYQUAL is a good company ? I think I have the answer because the board didn't look new and a few solder didn't look very well made.
    2. Can there be another reason beside the bad cap for the fuse on my power supply to always blow ? (Fuse at FE801 on the BN44-00175A board). I was thinking of a resistor but the one I tested (the one right besides the fuse) looked good. Maybe a diode but I don't have the tool to test it (well the only tool I have is a multimeter).
    3. I want to recap the whole board. Is there a place where I could find a list of all the parts I need instead of looking at all of them on the board and list them by myself ?
    Here's pics. The first 3 are from my original board and the 3 others are from the one I bought from BUYQUAL.
    Thanks a lot
  • Sony_crack
    • Dec 2020
    • 5
    Re: Help troubleshooting my Samsung Plasma TV FPT5084 PSU (BN44-00175A)
    Not that I could be much help, but if you still have the power board.......could you share was capacitor value is at CP814? It's right next to PFC hybrid near main filter caps. I received a board and oddly......that capacitor has been removed and I'm unsure what value should be there.
    • Sony_crack
      • Dec 2020
      • 5
      its 50V 10uF...i found it in a box ...
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
        by sam_sam_sam
        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
        12-16-2023, 08:39 PM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
      • HarleyFool
        Troubleshooting Samsung PN60E550D1FXZA Plasma TV
        by HarleyFool
        I have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
        I have removed the back of the TV and looked...
        12-21-2021, 02:40 PM
