Sony NSX-40GT1 - 2 Blinks
  • zdsh07p9
    • Nov 2013
    • 155
    Just got a TV in and the red standby light comes on, you turn it on and the green light comes on for 10 seconds then goes red, you can repeat once but after that you press the power button and it blinks twice. I think it something with the power supply, there is a clicking going on, not constant but when it cuts off it clicks
    Re: Sony NSX-40GT1 - 2 Blinks
    SM here:
    I cannot see any blink code listings. Very helpful, Sony...
    Start checking power supply voltages.
    • jason123
      Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
      by jason123
      Hi there,
      I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
      So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
      I see 2 posts that are relevant:
      https://www.badcaps.net/forum/troubl...j-oled-5-blink
      https://www.badcaps.net/forum/troubl...g-hardware-dev...
      10-29-2025, 02:01 PM
    • matwan
      Sony XR-55X90J 5 blinks
      by matwan
      I have problem with SONY 55X90J. After several check status is as below;
      1. Running power board as stand alone:
      TCON_12V =~ 12.6V
      EVDD V On Max 24V= 19V.
      2.
      Running power board with TCON as stand alone:
      Effect as below, attched.
      3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
      "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
      Best regards....
      09-28-2025, 04:26 AM
    • GoodCapDude
      Sony XBR-75X940E intermittent 6 blinks error code
      by GoodCapDude
      Hi everyone. First post on Badcaps!
      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
      09-20-2025, 06:07 AM
    • AK_777
      Sony KD-65A1 Repair – 4 Red Blinks Error
      by AK_777
      Hi everyone!
      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
      02-20-2025, 04:15 PM
    • jchon
      Sony A1e 5-blinks help
      by jchon
      Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
      I found the service manual, which was critical to know where to probe.
      https://www.manualslib.com/manual/20...1e-Series.html
      With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
      Unfortunately the 5-blinks...
      06-28-2023, 11:52 AM
