Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
  • tw2005
    replied
    Re: Panasonic Plasma TC-P50GT30 7 blinks SC board shorted
    Originally posted by billyac
    Regarding the following:
    ..."As for the SC50, disconnect, the 3 white connectors from the SC to the SD/SU. remove the 4 earth screws at the buffer boards. Jumper SC50. Turn the TV on and confirm it starts normally, no blinks and also if you view the TV from the rear on both the sustain boards there should also be an onboard green LED lit. This will confirm both boths are good and running."
    I am troubleshooting a TC-P55ST50. Does the quoted procedure above confirm the SC is good and SU or SD is not?
    Here's the history of what I did:
    1. TV went pop and started displaying 7 blinks.
    2. When thru troubleshooting flowchart from web
    3. Flow told me SD was bad ( I think- bottom one)
    4. Replaced that board from ShopJimmy.com
    5. It displayed a menu rectangle middle of screen with white horizontal lines near vertical center of screen (maybe some ribbons not seated properly?)
    6. After a few seconds back to 7 blinks.
    Ran thru flow again - isolated SU/SD and no blinks- says change su and sd
    I am hearing that I should replace SU, SD and SC but I am not sure.
    - with Grounds removed from SU/SD and white connectors lifted (3) and isolation jumper in place no blinks and green light on SC
    What I am not sure of is this:
    If White connectors are in place when I check continuity from floating ground to pins 2 and 6, they both show short on one or the other but no shorts when connectors lifted- checked from SC ground to pins 2/6 or from SC/SD grounds to pins 2/6
    Also, as per a youtube video, before replacing the SD board, I checked continuity from floating grounds on SU and SD to all ribbon connections and got some shorts on SD confirming that it was bad SD as the flowchart also indicated.
    Now (even after 7 blinks returned) I see no shorts on the new board
    But still 7 blinks and not sure what to do
    I cannot find exact service manual for this TC-P55ST50
    Don't see it here
    http://www.toms-service-manuals.com/...h=Submit+Query
    Does anyone know a compatible manual I can use?
    The one I have been using for flowchart is
    Model :TC-P50ST50* (America)
    replied HERE
  • billyac
    replied
    Don't see it here
  • billyac
    replied
  • tw2005
    replied
    Originally posted by behking
    Hi, I didn't risk it and ordered rjp30ha2 from another shop. Yesterday I had some time, so I opened tv and replaced( 3 30f131 and 3 rjp30h2a ) now tv work perfectly but I have a question about firmware. Is it really necessary to update firmware on 7 blinks of death? My firmware is 2117
    Thanks for your helping hands
    looks like that's the latest for your region anyway.
    http://av.jpn.support.panasonic.com/...own_aamo2.html
  • behking
    replied
    Originally posted by tw2005
    hard to say really. both rated at 35A but the 63 has a peak current rating 50A less at 200A.
    don't know what to advise, probably will work
  • tw2005
    replied
    Originally posted by larwil
    New member here. Have 2008 Panasonic th-c50hd18 with 7 blinking lights. Have read a lot of post and am starting with SC board. Have new SC board(TNPA4393) from ShopJimmy and want to test before attaching SD/SU boards. This model doesn't have SC50 jumper. other than disconnecting from SD/SU board and removing ground screws, what else do I need to do to isolate the SC board.
    Start a separate thread.
    read this. I think there's more chance on bad sd/su for 7 blink with these
  • larwil
    replied
  • tw2005
    replied
    Ok
    I received transistors today, but seller sends me RJP63k2 as Rjp30h2a replacement I saw Datasheets online except Collector to Emitter voltage these are the same, but because I am an amateur can you please see datasheets and say if I can use 63k2 as 30h2a?
    http://www.datasheet4u.com/datasheet....php?id=718438
    http://www.datasheet4u.com/datasheet....php?id=718452
  • behking
    replied
    Ok
  • tw2005
    replied
    Hi
    (First of all sorry for my English)
    I have a p50st30 with 7 blinks of death
    I live in a small town in Iran so I can't buy a repair kit from ebay - I search parts separately and find 30f131 rjp30h2 and rjp63g4 but can't find daf30 and rf1501 diodes and c08n25.
    I don't know are diodes infected or not, but I want to know are there any alternative for these parts?
    First step, verify what is shorted. Will probably find 30f131 rjp30h2 are, if they are remove and then check those diodes as there is a good chance they are ok so you won't need them. There probably are others that can do the job, just a matter of getting the specs and searching.
    can you get parts from china? UTSOURCE
  • behking
    replied
    Hi
  • cprem
    replied
    Sorry I meant the SC card and not SS.
  • cprem
    replied
    Update! I found one more IGBT shorted on the SS card after I wrote my last post, Q661 (RJP63G4). I have ordered it off eBay and waiting for the part to arrive. Will give you an you update once I receive the part.
  • marekk
    replied
    6 blink error is caused often by Q531, IC502
  • techknob1
    replied
    New member. First post ever. Working on 7-blink issue. I've read all posts.
    After replacing Q401,402, & 403 w/ parts from a 'Shop Jimmy' kit. I no longer have a short across SC2. At this point is it stupid to continue replacing parts, or should I proceed directly to the SC jig test w/ SU & SD disconnected?
    Also, does anyone have an opinion on a desoldering aid called 'Chip Quick'? Will its use lead to any problems down the road? Thanks in advance for any help.
  • tw2005
    replied
    are they blown again? Is there a triple set of rjp30h2 also shorted? Maybe the FET driver ics are bad too, did you check gate resistors.
  • cprem
    replied
    I am working on TC-55GT30 SC card with 7 blinks (caused by loose mounting screws on the board). Found 3 shorted IGBTs (30F131) Q621,622,623 replaced with new ones, did a resistance check on all remaining 30F131 and got a consistent reading of 47Kohm across pins 1 and 3(G&E) all gate resistors for IGBT's measured fine. Checked all diodes for shorts and none found. I installed the board back into the unit with only SC 02 and the ribbon cable connected and all connectors to SU-SD boards disconnected with connector SC 50 shorted fired up the Plasma set and I briefly got the green LED on SC board to light up and then buzzing sound from SC card followed by 6 Blinks. Anybody can help me further resolve this problem. Cheers.
  • tw2005
    replied
    there's no glass fascia, the crack is the PDP cracked.
  • tw2005
    replied
    Originally posted by Chaks
    Slightly cracked Panel ( 2 inch 'X' shaped crack on the left bottom side) got hit with a golf ball
    Plasma Panel lits up white screen for 2 seconds and shuts down with 7 red blinks ( blinking repeats with a 3 second pause)
    Here is the link to the Panasonic Plasma TV TH-P42XT50D PCB Imagesof my TV.
    https://drive.google.com/folderview?...Hc&usp=sharing
    Hoping someone can help me diagnose the problem
    Photos of everything except the panel fault and crack. I'm thinking chances are the panel is stuffed unless this has a fascia glass panel in front of the screen but if it shut down with 7 blinks after impact then, the impact was enough for panel shorted, also means the buffer board most likely shorted , also means SC also maybe bad but if the screen fires up briefly Sc could be ok. maybe the gas has not all leaked out yet but i think it's probably all over for this TV.
  • Chaks
    replied
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • Alicat
    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
    by Alicat
    Stopped by this site trying to fix my parents Panasonic Plasma TV.
    Model number is TH-50PZ85U
    Power comes on and the red power light stays on solid.
    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
    I also hear a few clicks.
    I also think my parents said there was a thunderstorm and the TV failed after that.
    Section 6 in the service manual talks about power and no screen,...
    10-30-2024, 10:09 AM
  • Yanleb
    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
    by Yanleb
    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
    D608, good
    D618 RF101L4S, good (See warning 1 below)
    D619 RF101L4S, good (See warning 1 below)
    D865 RF101L4S, shorted (See warning 1 below)
    IC464 Inverter HA MC74HC1G14, shorted...
    03-09-2020, 12:00 AM
  • nick31
    Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
    by nick31
    My Oct 2012 panny plasma quit working yesterday.
    It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
    Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
    I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
    04-21-2021, 09:56 AM
  • Biruslapio
    Panasonic P58V11B 8 and 12 blinks error "fix"
    by Biruslapio
    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
    04-13-2021, 07:13 AM
