Panasonic TC-L42U25 LCD Half Screen Bad - Good Pics (Come check out my caps)
  • biohzrd
    • Nov 2013
    • US
    Hi all!
    I'm trying to salvage my Panasonic TV that decided to give up the ghost while I was on vacation for a week. I tried searching for a few different phrases that turned up no luck. Most results that came back were for plasmas and not LCD's. Here are the searches I tried; maybe they will help someone in the future if I get this resolved:
    • panasonic half
    • panasonic half screen
    • panasonic tc-l42u25
    • panasonic tc-l
    • panasonic lcd
    TV: Panasonic TC-L42U25 42-Inch 1080p 120 Hz LCD HDTV
    Amazon Link: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Service Manual: Try here if that doesn't work
    Came back after a week of it unplugged to half the screen being distorted. The pics do it justice. Basically, 1/4 of the screen is white and the 1/4 next to it is a distorted fuzzy mess with some image showing. After reviewing the service manual, it looks like it MAY be the T-Con board. The service manual appears to rule out the LCD panel as the problem since it is in such a large area and not a thin vertical/horizontal line.
    I tried reconnecting all of the ribbon cables going in and out of the T-Con without any luck. I disconnected one side at a time while the TV was on and it didn't fix either side (like some YouTube videos suggested). Here is a picture of the back opened up.
    So my question is: Has anyone seen this before, is it obviously one thing or another?
  • Zelek11
    Panasonic Plasma screen interference on left half of screen
    by Zelek11
    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
    10-14-2022, 04:54 PM
  • armoured_smiler
    Panasonic Tx-40cx400b top left half screen not displaying correct
    by armoured_smiler
    Trying to work out if this is TFT problem or TCon issue.
    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
    04-08-2024, 03:40 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • renech
    panasonic TH-42PC77U plasma television half screen problem
    by renech
    hello,
    I hope someone on this forum can assist me.
    I have a panasonic TH-42PC77U plasma television.
    the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
    i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
    I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
    I have read some posts that suggest the problem is related to the boards on the left...
    12-12-2022, 06:53 PM
