Mitsubishi LCD LT-40134 vertical lines left side
  • m330437
    • Nov 2013
    My $1600 Mitsubishi 2008 LCD LT-40134 has solid vertical lines that start 3.5 inches from the left edge and continue for 14 inches, which is exactly middle of screen. They are not on the screen when the tv is first turned on. They typically appear after the set has been on for 30 minutes or longer, and do not disappear. What do you think the problem is, and could a mediocre handyman repair it himself?
    Thanks for any help!
    Jim
  • mmartell
    • Oct 2013
    • 3189
    Re: Mitsubishi LCD LT-40134 vertical lines left side
    Look up "tab bonds". You have to tear down your tv and see if these cables are not making good contact. In my case they were simply overheating and cooling them down restored the picture.
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • pni
      LG 49uf695v vertical coloured lines
      by pni
      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
      11-14-2025, 03:15 AM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
