TV EEPROM's and Firmware
  • Clydeuk
    • Jan 2012
    • 193
    Hi, not seen one on this site was wondering if there's a section for firmwares and EEPROM dumps, I seem to have a lot of sets with random digital faults (poor lipsync, no DVB etc.) that I'm sure firmware would sort out. Hard to get for the cheapo chinese and turkish made chassis. There's a Russian site that has some dumps but not easy to find anything. In particular for me I am after a dump of the Flash ROM on a Vestel 16MB1300-1 DVB module as the IC is damaged. I've bought a used board but I wouldn't mind tinkering while I'm waiting for it to arrive.
    Just a thought, it seems to me that people put up with these faults and use external sources until the set fails completely, then I end up with them and discover this after I've got life back in them.
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • Comps&Cons
    LG 34UC87C-B X3 Firmware Dumps all EEPROMS
    by Comps&Cons
    Don't know if this helps anyone but have just dumped all firmware for the LG 34UC87C-B, moreover has anyone already dumped the firmware for this wide monitor and if so can they check if its valid, the one i'm working on has no standby but all checkable components check out okay.
    Have zipped and uploaded all three pieces of firmware.
    PCB = EAX65923705 Rev 1.0
    IC205 MX25L8006E
    IC901 25X40CL
    IC102 24C02RP
    If not i hope it may help someone....
    03-10-2020, 06:53 AM
  • zzztann
    LG 34WR55QC dumps or firmware
    by zzztann
    I've been searching for days but couldn't find an EEPROM dump for my monitor. I tried flashing it using an MStar ISP programmer via HDMI, but something went wrong, and now the monitor is completely bricked—no display, no connection.
    On board says 34WP75C Questions:
    1. Does anyone have a working EEPROM dump for this monitor?
    2. If HDMI is dead, should I try desoldering & flashing the chip directly (e.g., with CH341A)?
    3. Any other recovery methods?
    05-21-2025, 11:27 AM
