techwood 37722hd faulty psu 17pw15-8
  • gary19610
    • Dec 2012
    • 74
    • uk
    I have a techwood 37722hd with a 17pw15-8 psu I have change 4 caps 1000uf 16v what was bulging but no look tv still not working.when you plug tv on blue light comes on and when you press button blue light go of and screen is still black with no picture no back lights psu is buzzing a bit to.any help please
    Gary
  • Clydeuk
    • Jan 2012
    • 193
    Re: techwood 37722hd faulty psu 17pw15-8
    Vestel power supply, I'd take a punt at the 15nF capacitors on the primary, there are 2 of them near the heatsink top left by the 2 FET's (which may also be short-circuited). Those caps fail frequently and are always worth replacing with a better quality component, they also cause random faults when they start to fail. These are polyester type caps not electrolytics, you might see a bulge in the side, but equally maybe not. If the FET's have failed you'll probably have an open resistor or fuse as well (i forget now as its been a while since I worked on one of these)
    The standby power circuit is separate if I remember correctly so a standby light is no indication of a working power supply.
    • gary19610
      • Dec 2012
      • 74
      • uk
      I have changed 15nf,s and fets seem ok but still get the same plug tv in blue light comes on press power button blue light gos of and nothing just buzzing coming from the power supply and the other buttons do nothing on front of the tv
      • Clydeuk
        • Jan 2012
        • 193
        I've got a diagram for this if it helps. You may have one already. Sounds like the main voltage rails aren't coming up so we need to know if the ST-BY on signal is reaching the main SMPS controller. I'm trying to pick my brain as I did a lot of work on one of these last year with several faults. A quick look at the diagram looks like the optocoupler IC8 is responsible for relaying to on signal to the main primary. There's an LM317T regulator involved there as well that supplies the primary SMPS controller I.C. I've heard mention of failure there but never had one gone, might be worth checking it's pins for voltage.
        • gary19610
          • Dec 2012
          • 74
          • uk
          could you send me the diagram please. I can see if I can work it out with the diagram my email is gary19610'live.co.uk
          thank you
          • gary19610
            • Dec 2012
            • 74
            • uk
            mine gary19610@live.co.uk for diagram
              Diagram:
              http://www.tgohome.com/ServiceManual...&Search=Submit
              Good luck decoding Vestel schematics... they're, uh, "special".
              • gary19610
                • Dec 2012
                • 74
                • uk
                think its down to the mainboard because the voltage on plug 803 the 34v stars dropping down and the 12v drops to 11v but unplug from mainboard and the voltages stay at 34v and 12v
                  Unlikely -- more like bad power board -- bad main boards are rare on this generation of Vestel and wouldn't usually cause that fault.
                  If you connect a car brake light to 12V and two 60W car headlights in series to 24V you should see same effect.
                  When first plugged in the power supply undergoes self test from main board: voltages rise for a couple of seconds then fall. Main board goes into standby mode. Then press power butotn, they should come up and stay steady. Or, the main board will shut down if fault detected giving a continuously flashing LED.
                  • gary19610
                    • Dec 2012
                    • 74
                    • uk
                    I get no flashing led and only get steady voltages when I disconnect plug 803 from mainboard. If connect plug 803 to mainboard and press power button for TV to come on the 34v on plug 803 starts dropping like 34 33 32 31 and so on and 12v go's to 11v and this is my 2nd psu with same tv fault so both psu are giving me the same fault on the tv
                    • gary19610
                      • Dec 2012
                      • 74
                      • uk
                      and I still get the buzzing out of both psu when I tried them one at a time the 2nd one is supposed to be fully working. The buzzing only starts when I press power button for the tv to come on. I have disconnect both back lights and still get the buzzing to.when I disconnect plug 803 buzzing go,s away
                        Check the voltage across the big 450V capacitor as it powers up: should be about 390V run, 330~350V standby. If faulty, will give around 330~350V continuously.
                        99% of these Vestels have power board faults: don't rule out the chance that you got the same fault across both models. They do have the odd inverter/t-con fault, but that causes other symptoms. I've never seen a main board on one of these go bad.
                        • gary19610
                          • Dec 2012
                          • 74
                          • uk
                          just wondering on the plug 803 going to the mainboard if number 4 pin yellow wire is ground because its reading ground with the black wires.it just reading ground on the mainboard but not on psu board.on the diagram psu its saying number 4 pin is AC-DIM-SEL
                          • gary19610
                            • Dec 2012
                            • 74
                            • uk
                            just put a new mainboard in and working ok hope fully will Carrie on that way thanks everybody for their help
                            • badcaphunter
                              • Jan 2016
                              • 88
                              • England
                              I had the same issue, unplugged the eeprom and it fired up.
                              • Tomylee
                                Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                by Tomylee
                                Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                Here's what I've observed:
                                All ribbon cables are properly connected
                                Battery is present and in good condition
                                No reaction even with screens disconnected
                                There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                06-26-2025, 02:33 PM
                              • blind2reply
                                proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
                                by blind2reply
                                proscan 40ld45q
                                Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
                                After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
                                No sound, no picture (used flashlight test).
                                No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
                                Digital voltmeter;...
                                06-06-2021, 01:16 PM
                              • TurboTundra
                                PS5 EDM-033 Blue Light 2 Sec then Powers Off
                                by TurboTundra
                                Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                                The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                                Thank you for any input...
                                06-10-2025, 08:51 PM
                              • icareservicezone
                                Synology DS918+ blue light blink
                                by icareservicezone
                                Synology DS918+
                                Model name : GDI41L2
                                p/N: 08-06GDI4116
                                Version: V1.6
                                Problem : blue light blink...
                                05-24-2025, 11:53 PM
                              • cajoeg
                                Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                by cajoeg
                                Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                02-10-2025, 04:01 PM
