Lg 50pg3000
  • JonTractor
    • Nov 2013
    • 5
    • United Kingdom
    Lg 50pg3000
    Hello, I have an LG 50PG3000, I am hoping you can help me with a problem. I have this red and black bar running across the top of my screen. It is always there regardless of source, any idea what it could be and if it can be fixed? It appeared one day and has stayed ever since.
    Any help really appreciated
    Re: Lg 50pg3000
    I would say a defective upper buffer board. There's a small chance that the plasma panel could fail in such a way to damage this board, but I've never heard of that happening on an LG plasma.
    • JonTractor
      • Nov 2013
      • 5
      • United Kingdom
      Re: Lg 50pg3000
      Cheers for your help mate, if I was to change this myself is there anything to watch out for? I have worked on PC's for 15 years never touched a TV though.
        Re: Lg 50pg3000
        Unplug for at least 2 minutes before commencing work, do not change any connectors while energised or up to 30 seconds after working on set. Set can be tested with back cover removed after installing new part for a short period of time.
        • JonTractor
          • Nov 2013
          • 5
          • United Kingdom
          Re: Lg 50pg3000
          Cheers Tom, really appreciate your help. Will let you know how it turns out
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • Takeatry
            Yet another Samsung QLED Boot Loop
            by Takeatry
            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
            10-04-2024, 02:57 PM
          • bdalkiran
            55EC930V white vertical line appeared (need help)
            by bdalkiran
            Dear All,
            I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
            Please advice how to proceed and what is the...
            01-13-2023, 04:16 PM
          • notallbad
            TCL 55RP620K power board issue
            by notallbad
            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
            0% p_dim at 1.65v and a_dim at 1v
            50% p_dim at 3.3v and a_dim at 1.65v
            100% p_dim at 3.3v and a_dim at 2.88v
            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
            Leds are 2 rows of 15 6v leds.
            On inspection of the power board found diode MBR3200 shorted so replaced with...
            07-12-2025, 05:45 AM
