samsung pn58a550 main board compatibility?
  • j sizzl
    • Oct 2013
    • 16
    • United states
    is a samsung pn58a550 bn94-01880a, b, c, d, e. compatible with a
    BN41-00975B,Samsung LN40A550 Main Logic Board BN97-01985T?
    Re: samsung pn58a550 main board compatibility?
    Probably not - Samsung LCDs usually use different main boards to their plasmas.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      I have a good one from cracked screen.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
