Sony KDL 40WL135 showing Double image
  • howardc64
    TCL 49S405 double image
    by howardc64
    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
    06-23-2025, 03:20 PM
  • Cornito
    Samsung UE55RU8000 reboot and then double image after heating up
    by Cornito
    Hello team,
    I'm back with another tv and another problem.
    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
    First, reboot issue, I use tape Method to find out the right side that cases the issue.
    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
    Then double image reduce in height and move to the top.
    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
    When I...
    03-31-2024, 01:37 PM
  • rimwall
    Sony KD-65x7500D - double image - Tcon or Panel?
    by rimwall
    This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
    I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
    11-18-2025, 02:09 AM
  • NSkyLab
    Sony XBR-65X900F black and white image on one side (fading saturation)
    by NSkyLab
    I though I've seen all possible kinds of failures but this one is new...
    Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
    I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
    Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
    10-05-2025, 07:37 PM
  • domix
    Sony KD - 65XF9005 - No image, sound OK
    by domix
    at tv KD - 65XF9005 i have a problem.
    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
    is this a common problem for this tv?
    i attached pictures of inside. Supply board looks okey, no blowed caps....
    07-21-2025, 06:37 AM
