LG 32LG7000 Fault
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    LG 32LG7000 Fault
    Hi, I have this 32LG7000, when i turn it on sometimes it will work fine but most times the backlight just flashes on and off every few seconds and is unresponsive to any input remote or side buttons. Would anyone know by looking which board is the fault, I suspect its the inverter but i just want to find out for sure,
    Here's a video of the fault.. :-)
    http://img203.*************/img203/8...gxuyasldix.mp4
  • Rictech
    Panasonic SA-MAX770PU SMPSU board fault....
    by Rictech
    Hello everyone. 😀
    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
    There are no devices that have exploded or otherwise show signs...
    08-26-2024, 01:05 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
    ESR meter came to the rescue again today with a PLC I/O card fault
    by sam_sam_sam
    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
    12-18-2023, 08:17 PM
  • Agent24
    What kind of fault causes this image error?
    by Agent24
    I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
    The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
    What's the most likely cause of this problem, does anyone know?...
    09-22-2025, 11:42 PM
