LG 50PJ350 dead, relay clicking
  • aasnowskate
    • 118
    • usa
    I have a LG 50PJ350 that is not working. I looked through some other posts and found similar problems and did some work before posting this.
    I found one bad resistor on the Power Supply board. I replaced it and the resistor beside it. They were both 22w 5 ohm.
    The problem still was the same. I noticed that the D201 was not lighting on the Main Board. So, I replaced the main board and the problem is still the same. I was getting all the proper voltages to that board from the YSUS board, so I thought it was bad.
    Today, I went back through and started unplugging the YSUS and ZSUS from the main board. With the YSUS unplugged and everything else plugged in, there is audio and it doesn't cycle throught the relays like it did before, it stays on.
    With the YSUS plugged back in and the buffers unplugged, it goes back into the standby shutdown mode.
    I am thinking YSUS now.
    Any suggestions to try?
    Thanks in advance.
  • tw2005
    • Oct 2011
    • 6458
    Re: LG 50PJ350 dead, relay clicking
    Did you find the zenith 50pj240 post? Sounds familiar though he's yet to get it going and check out the sustains and buffer boards. There's a training guide I uploaded for your model. The ysus and zsus power are chained which I hate for fault finding.
    All I can suggest is to check Ysus,Zsus & buffers and see if anything is shorted. Maybe measure the resistances at the power connectors e.g Vsus etc.
    I have a full set of boards for comparison for this one.
    The training guide has some good info and checks in it.
    Z50PJ240
    • aasnowskate
      • 118
      • usa
      Thanks for the reply. I will check the resistances and get back to you.
      • aasnowskate
        • 118
        • usa
        I can't view the training manual you posted in the Zenith post. Is there another link to it? My computer will not allow it to open.
        • tw2005
          • Oct 2011
          • 6458
          It's compressed with winrar. I can find the link for direct download for you, once these get to the size limit I have to use RAR so the forum takes the upload.
          • tw2005
            • Oct 2011
            • 6458
            2 free downloads per 24hr
              Block diagram may help too
              As might alignment details for panels, including PDP50T1 in this set.
              • aasnowskate
                • 118
                • usa
                Thanks for the info. That service manual and block diagram from Tom came up for me. I did the light bulb test on the power supply just to rule that out and it worked fine. It kept the lights on for several minutes.
                I also checked the two buffer boards coming off the P212 connector from the YSus. I checked them for shorts and found none. I am thinking it is the YSUS. I don't have a scope to check the YSUS like it says to do in the manual. Is there anything you think I could check with a DMM before ordering the YSUS board?
                The least expensive one I can find is $175 on ebay.
                • tw2005
                  • Oct 2011
                  • 6458
                  Geez, you're kidding. They must be in high demand.
                  I'd check Ysus and Zsus in case. Pick a point I guess. measure the resistances on the power connectors on the YSUS and post. I've got my board here, it's getting late so I'll hang on otherwise it'll be tomorrow .
                  Don't know much about these, tried a Samsung with chained boards at component level and gave up. ended up replacing the 3 boards at once.
                  Did you try Tom's control board test bypassing the main to see if the panel fired up?
                  • aasnowskate
                    • 118
                    • usa
                    Am I measuring VS to Ground?
                    • tw2005
                      • Oct 2011
                      • 6458
                      You sure about the price? I see cheaper and brand new here $70 plus freight from LG! And we're usually the ones that get ripped.
                      Are there any LG direct parts sites in the US?
                      I suspect EBR63039801 , EBR63039802, both will work
                      • tw2005
                        • Oct 2011
                        • 6458
                        Start there, it may charge up and change. Just let me know the steady figure and which way you have the probes. Is it a quality meter you have ?
                        • aasnowskate
                          • 118
                          • usa
                          I just found the EBR63039801 on Ebay for $96. Where are you looking? I am not sure if the 801 will work or not. I emailed the seller, we will see. I have to go out of the shop for a bit. Let me know if you find anything and where I am looking for the resistances. Thanks for all your help so far TW2005.
                          I will look a little more for the board.
                          • aasnowskate
                            • 118
                            • usa
                            It does charge up at 1400 ohms and change to open with the DMM. When I use an analog meter from Ground black probe to VS red probe I get 10000 ohms steady.
                            • tw2005
                              • Oct 2011
                              • 6458
                              This is my DMM , old fluke 73 auto range.
                              Initially 300K, take off and on again, 2.8meg
                              In diode mode it simply charges starts at 0.4, continues just past 2 and goes OL.
                              Short Vs and gnd pins and see if the result is similar to mine.
                              gnd-Va I get 4.1meg, diode similar to Vs 0.4 - 2 then OL, won't repeat unless Va and gnd are shorted to discharge cct.
                              gnd-15V beeps initially but charges to 0.95, resistance is all over, starts low , k ohms then jumps to 2-300k then lift off and on goes to 2-3meg.
                              There's a couple of pico fuses, not sure if they're worth checking.
                              I can see myself looking a bit silly here, if these don't present a dead short somewhere and fail in some other manner.
                              • tw2005
                                • Oct 2011
                                • 6458
                                LG here in Aust, http://www.electronicmarket.com.au/5...5735_5736.html
                                freight would kill it but the US being such a huge market I'd expect a similar price and a website that retails these too?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  sears $110 http://www.searspartsdirect.com/part...rt=EBR63039802
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    You may like this I found , reclaimed $30 and they state the 9801 board will work and another.
                                    http://www.encompassparts.com/item/8...t_Pcb_Assembly
                                    http://www.encompassparts.com/item/8...vtp_Board_Assy
                                    http://www.encompassparts.com/item/8...1/Ydrvbt_Board
                                    http://www.encompassparts.com/item/8...40301/Zsus_Pcb
                                    Just over a $100 for all if I'm seeing right>
                                    • aasnowskate
                                      • 118
                                      • usa
                                      Thanks for that TW. I ordered it through the link you sent me. For $30 it is worth getting it and if it doens't work, I will be able to resell it.
                                      Thanks for all the help. I will post my results when I receive the board.
                                      • aasnowskate
                                        • 118
                                        • usa
                                        I got the new YSUS. Put it in and got the same result. When I first plugged it in, the YSUS made a different noise like something burnt out. When I unplugg the Ysus, I have audio, in the form of static noise. I don't know what to think.
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • Donny2derby
                                          LGOLED55B7V Clicking and dead screen.
                                          by Donny2derby
                                          Picked this up other week and when I originally looked at in the sellers house I got 3/4's of a working screen and some horizontal lines across the 1/4 of it which was dead/black.
                                          Just tried powering it up at home and now all I'm getting is a clicking and some very faint lines on 1/4 of the screen whilst the entirety of it is dead.
                                          When using the remote I get two red clicks on the standby. Not sure if this means anything or helps. The same when I use the manual power up.
                                          Help appreciated. I'm an electrician, I've fixed a few in the past so not a total...
                                          08-10-2023, 04:23 AM
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
