How are inverter boards controlled ?
  • 120volts
    • Oct 2013
    • 57
    Hi I'm new to the Badcaps forum.
    I took a four years coarse in electronics at a tech trade school and then worked for over fifteen years for various companies as a bench tech.
    Here's my question.
    On the typical CCFL backlight inverter board how is the brightness controlled?
    Is it by raising or lowering the control voltage or is it controlled by varying pulse width?
    Dan "TV Tinkerer"
    Re: How are inverter boards controlled ?
    The DIM signal an analog voltage typically from 0 - 3.3V which controls brightness from approx 10% to 100%, or a PWM signal (pulse width modulation.)
    Note minimum brightness around 10% for CCFL because they cannot go below that without having to re-ignite which takes about a second to occur.
    • 120volts
      • Oct 2013
      • 57
      Thanks for the replay Tom.
      Time to get the scope up and running.
      Dan "TV Tinkerer"
      • 120volts
        • Oct 2013
        • 57
        Ok, when I turn on this DX-LCD32-09 Dynex I get sound but back-light for only 1 sec.
        The inverter board is getting the 24V and 5V. and on the PWM I get a steady +3.4V
        with the scope I don't see any pulse or frequency at all.
        Dan "TV Tinkerer"
          That is the 2-second to black problem which can be the MOSFET, Inverter transformer, CCFL, etc.
          https://www.badcaps.net/forum/showthread.php?t=10419
          • 120volts
            • Oct 2013
            • 57
            OK thanks for the links but, my question was should I be seeing a control pulse?
            I bought a used inverter board and was told it was working 100% and the TV still has the same problem.
            Dan "TV Tinkerer"
              The PWM is about 200Hz. But does it also has another connection for the analog dimming? Set your meter to AC to see if you will get any AC voltage. Board P/N?
              Is this the board, which only has PWM only.
              http://www.shopjimmy.com/vit68001-95...t-inverter.htm
              According to what I found about your LCD panel spec, the PWM can be fed with Anolag signal.
              https://cdn.badcaps-static.com/pdfs/...4256d2d602.pdf
              3.3VDC = Max brightness. If this is the panel you have.
                You probably have "2 seconds to black". This occurs when the set detects an open or shorted bulb in the panel, which causes it to shut down after the ignition phase (2 seconds.)
                  I agree.
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • ugamazing
                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                    by ugamazing
                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                    12-17-2024, 07:05 PM
                    MSI Gaming Pulse GL66 12UGK-470CA Notebook GL Specification for Upgrade or Repair
                    This specification for the MSI Gaming Pulse GL66 12UGK-470CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL66 12UGK-470CA boardview and Pulse GL66 12UGK-470CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:40 AM
                    MSI Gaming PULSE GL76 12UEOK-692FR Notebook GL Specification for Upgrade or Repair
                    This specification for the MSI Gaming PULSE GL76 12UEOK-692FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL76 12UEOK-692FR boardview and PULSE GL76 12UEOK-692FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:38 AM
                    MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook GL Specification for Upgrade or Repair
                    This specification for the MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL66 12UGSZOK-1096 boardview and PULSE GL66 12UGSZOK-1096 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
