Technosonic LCD3251 Main A/V issues
  • notallbad
    • Oct 2012
    • 1190
    I believe this tv requires a new board, video input issues.
    Main A/V board: AM005AC
    There are a few boards currently available relatively cheap but which one?
    AM005AC
    LM005AD
    LM005AC
    They all look similar in physical size and just as importantly have all the same ports in all the right places to line up with the rear casing. Also the wiring connections look the same in the same places on the board and look the same size etc..
    How do I know which ones have DVB? This would be preferable. One of them has 2 tuners on it, is that a clue?
    Is it likely that the T-Con connections will be the same, don't fancy re-wiring this or likely the panels used were different?
    Re: Technosonic LCD3251 Main A/V issues
    Most DVB sets have a CI slot for the Common Interface module, this is a requirement for Freeview.
    As for model # of board you need to check it's used in same panel as yours currently is.
    • notallbad
      • Oct 2012
      • 1190
      Well both the LM005AC and AD say came from an Technosonic LCD3251 but could be different panels in each, wouldn't have a clue which they use.
      • notallbad
        • Oct 2012
        • 1190
        my panel is LC320W01-SL01
        • notallbad
          • Oct 2012
          • 1190
          To be honest I think this board just needs firmware but as I don't know how to do that its gonna have to be a board replacement.
            Only the seller can tell you which panel it used.
            • notallbad
              • Oct 2012
              • 1190
              Doubt they know but shall ask.
              The other thing is theres a board AM005AC thats the same as mine but came from a 26", would it just be a simple change in Service Menu to 32" from 26"?
                If same panel but different inch then no problem.
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Asraf Atb
                  Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                  by Asraf Atb
                  Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                  Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                  I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                  01-27-2025, 05:02 PM
                • benwaterson
                  Main rail / charging circuit issues on Bucky/BenSolo 17859-1 board from Dell Vostro 5581
                  by benwaterson
                  Hi All
                  Been a while since I have been here, and a bit rusty.
                  I have the above laptop motherboard that was working and now the charging circuit is faulty.
                  Have 19v in fine until it hits PU4403 - not shorts I can see and thermal cam reveals nothing.
                  I have swapped out the ISL9538 and also the two mosfets (PU4403 and PU4405). Have 2.8v at the power switch, which pulls low when pressed - charging light comes on and goes straight off
                  Below are measurements (pin names are per the datasheet for the ISL95338 (couldn't find one for ISL9538,...
                  05-03-2024, 03:25 AM
