from what i can tell so far, im not getting 12volts from the power board when the tv is turned on. i get all other voltages, like 5v and the 2volt for the inverter on/off. here is the power board, its the kind that powers inverters all in one i think. can anyone point me in the right direction? thanks
Vizio VS420LF1A, no sound, no backlight and no pic.
Tags: None
Re: Vizio VS420LF1A, no sound, no backlight and no pic.
ok, if i leave it unpluged for a day or so. it will power up fine. Im pretty stumped, maybe a cold solder somewhere? -
When you do get it to power on, make sure to turn the sound up and select a working source. Wait for it to fail, do you get sound in the failed state?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
does get sound in faild state tom66, what does this mean?Comment
It means the main board is working fine but you are losing the backlight power. Therefore, concentrate any soldering work around the backlight transformers, their connections and the heatsink with the driver FETs on it. (this is the one near the two backlight transformers.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
my sister says it still gets sound when the pic goes out. will check it for myself and get back out the solder iron if it does. thanks, will post back soonComment
ok, it does not get backlight or data to the screen. and it does not get 12v from the power board. does get 2.5v on the ps on/off and 5v where its supposed to have output. how can i get the 5v and not the 12 from the board?Comment
Assuming...7 Photos -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
