LG37LF66 - video but no sound - not t-con not power supply
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: LG37LF66 - video but no sound - not t-con not power supply
    Well after heating the PSU and encountering the issue it certainly points at the PSU failing.... Can you take the reading in order from the psu to the mainboard and note each one down whilst fine/flickering and off and post results here.
    E.g
    FINE:
    Pin 1 - 0VDC
    Pin 2 - 5VDC
    Pin 3 - 12VDC
    Flickering:
    Pin 1 0VDC
    You get the idea.
    • zelig880
      • Sep 2013
      • 28
      • wales
      well I have done my check.. and I think it will be quite unsuccessful...
      Unluckily the flichering is not long enought for me to get the reading.. but they seems the some also when it was flickering..
      I will use the hair dryer again to focus on the mainboard. I think it is the issue.. i watched tv with the board sligly lifted ( to increase hair flow and I managed to watch tv for over 2 hours.. ). Just a few extra points, the screen resolution changes every 5-6 minutes.. its just slightly.. but it streaches.. and then stretches back after few minutes...
      for example on e4.. i can see the singer name and the title of the song, that i change and the song name is out of the screen.. then change again.. and so forth... there is no real patter..
      Another point is that if I watch HD channel the problem comes earlier ( but i assume is because it makes more effort to show the program..)
      This are the reading..
      PERFECT VIDEO:
      starting from the top connector with 13 pins:
      PIN1 5.10
      PIN2 2.8
      PIN3 5.03
      PIN4 -
      PIN5 4.38
      PIN6 3.10
      PIN7 1.66
      PIN8 5
      PIN9 -
      PIN10 -
      PIN11 2.4
      PIN12 6.20
      PIN13 0.86
      second connector strating from the top:
      PIN1 18.7
      PIN2 18.7
      PIN3 -
      PIN4 -
      PIN5 6.2
      PIN6 -
      PIN7 3.4
      PIN8 -
      PIN9 12.2
      PIN10 -
      WHEN THE SCREEN WAS OFF:
      PIN1 5.10
      PIN2 2.8
      PIN3 5.03
      PIN4 -
      PIN5 4.38
      PIN6 3.10
      PIN7 1.65
      PIN8 5
      PIN9 -
      PIN10 -
      PIN11 2.4
      PIN12 6.20
      PIN13 0.86
      PIN1 18.7
      PIN2 18.7
      PIN3 -
      PIN4 -
      PIN5 6.2
      PIN6 -
      PIN7 3.4
      PIN8 -
      PIN9 12.2
      PIN10 -
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • soeren
        A2442 - No sound over internal speakers and no video playback
        by soeren
        I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
        All happened after the battery ran out of power overall several days when I was on vacation.
        I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
        07-26-2024, 01:24 AM
      • JRade
        Audio video receiver KENWood KR-V990D,no sound
        by JRade
        When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
        The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
        I replaced the capacitor C303/0.047F, nothing changes.
        I'm asking for help, what should I do next?
        Thanks in advance!...
        08-05-2025, 10:23 PM
      • larSS
        MSI MS-16JF no video memory power supply
        by larSS
        Hello! Has an msi ms-16JF motherboard with a diagnosis "doesn't work". There were a short-circuit on video memory lane. Removed GPU and video memory, changed TPS51916 and transistor on it's lane. Motherboard works OK, has the initialization and video card voltage. But has no video memory voltage. Should there be a video memory voltage without video chip or no? Has the S5 signal 3.3V on TPS51916
        10-28-2023, 09:24 AM
