the TV has double image and the top image is sharking i have cheeked all the caps in the power stage and all is good. do any one knows what is wrong please
SAMSUNG le32c350d1wxxc with double image
Re: SAMSUNG le32c350d1wxxc with double image
Moved from FAQ to TV section.I love putting bad caps and flat batteries in fire and watching them explode!!
by CornitoHello team,
I'm back with another tv and another problem.
I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
First, reboot issue, I use tape Method to find out the right side that cases the issue.
Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
Then double image reduce in height and move to the top.
The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
When I... -
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by howardc64LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board... -
by shlomim412hi
having problem with samsung ua55es6800
tv had backlight on, sound working - responds to the remote control but no image.
check tcon board - had 12v in but no other voltages present.
when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
when leaving only left side connected - again no voltages and no image.
put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
kept trying to block less pins on the left ribbon cable... - Loading...
