Philips 42PF9731D blinking error code
  • PowerAmpFreak
    • 982
    • Sweden
    Hello!
    This Philips 42PF9731D amberlight unit does blink error code 12 (one long and two short blinks, then a delay of 3 seconds)
    Which according to service manual is +12V failure.
    Any advice what use to get bad here?
    Re: Philips 42PF9731D blinking error code
    Checked the +12V on PSU first?
    Shorted diodes, bad caps, main board short...
    • PowerAmpFreak
      • 982
      • Sweden
      It appears the +12V line is low (like 9.8V) even if the connector is disconnected (with the load).
        Check for bad cap on 12V rail. Pictures of boards?
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • mecha1166
          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
          by mecha1166
          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
          03-28-2024, 08:31 AM
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • eurgenca
          Philips TV 43pus7505 setting display option code, help please.
          by eurgenca
          Hello.
          I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
          So I ordered a used CPU board, and now I have wired picture.
          I think the problem lies in display option code. According to SM, the command for setting
          display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
          But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
          or can I manually edit option code in SAM.​
          10-07-2024, 02:09 AM
