westinghouse LD-4255VX right side dark
  • lookimback
    • Aug 2013
    • 1489
    Got a new project today. Westinghouse LD-4255VX. Problem is that the right side is real dark. My first thought was TCON but then I opened it and found that it doesn't have one. This is my first LED TV. Have to say I'm a little surprised after opening it and finding that it only has 1 board. Doesn't appear to have any physical signs of component failure. Any ideas?
    Edit: I tested the power supply. It doesn't resolve like I would expect. It fluctuates between 18v and 19v. No way to open it that I can see.
    ------------signature starts here------------
    Re: westinghouse LD-4255VX right side dark
    46" version but same fix:
    https://www.badcaps.net/forum/showth...ight=LD-4655VX
    Easy fix if you know what you're doing and are careful around the LCD panel.
    • lookimback
      • Aug 2013
      • 1489
      I was reading that thread this morning. So it could just be the ribbon cable? I don't see the other end. I guess I will have to remove the front bezel to see it. Would that be correct? Also, thank you for the quick reply.
        Looks like the front bezel side to me... but best to ask them as I'm not certain.
        • lookimback
          • Aug 2013
          • 1489
          All the LEDs light. I had to completely remove the panel and the screens under them to get to the ribbon cables. They are good though. I did use my tweezers to straighten out one spot on the other end of the cable. Maybe that was it. I will put it all back together and see what happens.
          • lookimback
            • Aug 2013
            • 1489
            All the LEDs light. Still dark on right side. Could the main board be the problem? Or, the panel could be bad?
            • lookimback
              • Aug 2013
              • 1489
              I just noticed that the dark side also has a slow refresh rate.
              Edit: it looks almost perfect if its a white screen but dark images are too dark.
              • lookimback
                • Aug 2013
                • 1489
                Here's a couple pics. I also noticed that on the right side it flickers sometimes and i can see scanlines.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I'm no expert by any means but I'd suspect panel at this point. I've ready too many bad reviews with the Westinghouse brand. Just my two cents though.
                  • lookimback
                    • Aug 2013
                    • 1489
                    I was thinking the same thing. I'm sure I can part it out and get my $80 back.
                    • lookimback
                      • Aug 2013
                      • 1489
                      Would it actually be the panel or something with the board attached to it?
                      • lookimback
                        • Aug 2013
                        • 1489
                        I'm beginning to think its not the panel. I've been doing a lot of reading and most of the TVs with bad panels will clear up a little if you flex the panel a little. Also, its to even. Its as if there is an invisible line right down the middle of the screen. Every thing to the right of that line is darker. From what I've seen of bad panels, its usually areas of dead pixels but not one was exactly one half of the screen. I'm leaning toward a bad IC, or some other component, on the panel board. I'm going to try to find all the data sheets for the ICs and see what they are and try to narrow it down. Hopefully, if it is an IC, I will be able to find a replacement. Would be great if someone had a cracked panel and could just tear the board off and sell it to me. I could then just use my rework station and swap the ICs one at a time.
                          It looks like the right hand LED strip is dark, it's possible for the main board to go bad causing this.
                          • lookimback
                            • Aug 2013
                            • 1489
                            It looks like that but from the back you can see its on. I actually removed the panel and tested it. All the LEDs lit. BTW, they are bright. Sunglasses would not have been a bad idea, Lol. Refresh rate is very slow as well. I connect my laptop through HDMI and move the mouse and it has a trail behind it. I'm on my way home from work now and will get a pic of this and post it.
                              Ah, if the refresh rate is bad it is probably the panel tab bonds that have gone bad. May or may not be fixable
                              • lookimback
                                • Aug 2013
                                • 1489
                                I was hoping that wouldn't be it. Here's the pic of the mouse pointer.
                                Edit: still though, wouldn't a bad tab leave me with lines or something? Would it affect exactly one half of the screen?
                                  Bad tabs can affect halves of panel and also affect motion blur without any other problems.
                                  Symptoms vary. Sometimes you have vertical lines, poor refresh rate, double images/stretched images, flipped image (very odd one!), wrong colour, blurred image...
                                  • lookimback
                                    • Aug 2013
                                    • 1489
                                    Is there any way to test it? If its the tabs then I'll just part it out to get my money back but would want to know for sure I was selling good parts.
                                      Well tab bonds CAN be fixed but success rate varies... I've had some good for over a year (as has budm) & some fail in a day.
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        How are they fixed?
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
                                        • FitPaul
                                          HP ENVY all-in-one 27 b208na screen dark one side
                                          by FitPaul
                                          I have a HP ENVY all-in-one 27 b208na with the screen dark on one side. I expect it's due to a faulty back light or inverter on that side.
                                          My question is where is the inverter located? In the base or behind the display. How do I dismantle the display to check the backlights? I tried to take off the back cover but it cannot be removed completely so does not give good access to the display. Should I gain access to the display from the front?
                                          10-31-2022, 05:41 AM
                                        • flibidy
                                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                          by flibidy
                                          I have here a Magnum IA.100 which belongs to my parents.
                                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                          What Ive done........
                                          01-01-2025, 01:26 PM
                                        • sputnikoff
                                          Samsung un50nu7100f dark screen right most side.
                                          by sputnikoff
                                          Has anyone out there run into screen dark on right most side on a Samsung un50nu7100f. I had half screen at first replaced the strips and back light is lit really good, actually it's brighter than left side when u lift the panel.I assume the panel is toast?...
                                          11-11-2021, 10:24 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
