Hisense lcd40v57ca buzzing
  • kodiac
    • Jul 2010
    • 116
    I would appreciate if someone could help me with a Hisense lcd40v57ca which has a buzzing sound from the back, that sounds like high voltage arching/escaping?
    A 390uF 250wv cap on the power supply board is swollen up on top.
    Also the tv will cycle on/off after it has been on awhile.
    Does anyone know where I can obtain a 390uF 250wv cap in Canada?
    Thank You
  • kodiac
    • Jul 2010
    • 116
    Re: Hisense lcd40v57ca buzzing
    Help Please?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      You can find a cap in that size at Digi-Key. What was the original brand of the capacitor, and what are the dimensions of it? If the power board used cheap caps throughout it, while you're at it you might want to replace the rest of those too. Pictures are welcome
        Often the plastic dome of a capacitor can bulge without the capacitor being failed, if it has a plastic cover. If you can push the dome down flat, the capacitor is likely OK.
        • kodiac
          • Jul 2010
          • 116
          Thank You.
          Sorry for the picture quality.
          LCD40V57CA
          I have to open the TV again for the caps names.
          • kodiac
            • Jul 2010
            • 116
            The largest cap 390uF 250wv 105deg ( 3 cm x 3 cm ) which is bulged, is a brown SamYoung cap.
            Others have TLC and S symbols.
            The 390uF cap seems to be buzzing when the TV is On and emitting a whistle when the TV is Off/Standby.
            When the TV is turned ON the buzzing begins and after approximately 15 min. the screen begins blinking periodically.
            Does anyone have a list of good cap manufacturers.
            Thank You.
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Thank You
              Where in Canada are you?
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • kodiac
                • Jul 2010
                • 116
                Bump
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  This will work:
                  http://www.digikey.com/product-searc...=0&pageSize=25
                  • kodiac
                    • Jul 2010
                    • 116
                    Thank You Sir.
                    • kodiac
                      • Jul 2010
                      • 116
                      Is it true that increasing the voltage of a capacitor ( ex: 250wv to 350wv ) will shorten the life of the board.
                        If anything the complete opposite. The capacitor voltage ratng is a maximum, not what it operates at.
                        • kodiac
                          • Jul 2010
                          • 116
                          Thank You
                            The main issue may be dimensions - check capacitor will fit before ordering. Compare dimensions on the Digikey page to the physical dimensions of the failed capacitor.
                            • kodiac
                              • Jul 2010
                              • 116
                              Thank You
                              • kodiac
                                • Jul 2010
                                • 116
                                  Panasonic, Rubycon, United/Nippon Chemi Con, Nichicon, Sanyo/Suncon, Fujitsu.
                                  • kodiac
                                    • Jul 2010
                                    • 116
                                    Thank You
                                    • kodiac
                                      • Jul 2010
                                      • 116
                                      Replaced 390uF 250wv cap ( with 300wv Panasonic from Digi-Key) in the power supply.
                                      Problem solved, no more buzzing.
                                      • kodiac
                                        • Jul 2010
                                        • 116
                                        Anyone familiar with a pair of faint light horizontal lines moving up the LCD screen which are most visible on dark background or night time programs?
                                        I think these lines were called sound bars on older CRT televisions.
                                        • EUWest
                                          Hisense H49M3000 PSU buzzing + Black screen after 20min
                                          by EUWest
                                          Hey Folks just got another Hisense with an unusual Problem.
                                          After plugging in its starts buzzing on the cold side. Could not located it 100%, but seems like transformer/capacitor.
                                          TV has 1 horizontal Line, often static. After 10min screen gets flickering and after about 20min screen gets Black while Sound is on. After turning off and on screen appears back for about 5min and then went Black again.
                                          I checked LED Voltage:
                                          While Screen is on about 115v
                                          While Screen is Black also about 115v
                                          LED Connection unplugged also 115v
                                          09-12-2021, 11:09 AM
                                        • tomketcz
                                          schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                          by tomketcz
                                          Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                          10-01-2025, 03:13 AM
                                        • Coolgoodman
                                          Faulty Hisense 85Q6NAU TV
                                          by Coolgoodman
                                          85” Hisense TV
                                          Greetings,
                                          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                          Dear TV technicians of forum, I hope this message finds you well.
                                          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                          07-24-2025, 03:02 AM
                                        • ShahZaib Ghumman
                                          Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                          by ShahZaib Ghumman
                                          Hey folks,
                                          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                          03-25-2025, 10:59 PM
                                        • nono34
                                          Hisense stuck in Colors cycle like test pattern.
                                          by nono34
                                          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                          10-24-2024, 04:31 PM
