PN50B400P3D 50" Samsung Plasma Won't Turn On.
    Re: PN50B400P3D 50" Samsung Plasma Won't Turn On.
    Unplug Y-buffer, does -Vsc rise?
    • Dowd, Elwood P.
      • Sep 2013
      • 39
      unplugged the Y-buffer & no change
      I'm putting the red lead on the VSC point & the black lead to the chassis screw. The same as I did on the other test.
        If that is the case, your (new) Y-main is bad.
        • Dowd, Elwood P.
          • Sep 2013
          • 39
          Could the adjustment screw be turned all the way down? Could something else be bad & have fried the new Ymain when I put it in?
            You can test your Y-buffer.
            The min -Vsc is not 0V (more like 60% of max), but you can try adjusting it anyway.
            https://www.youtube.com/watch?v=51SZsfH60EY
            • Dowd, Elwood P.
              • Sep 2013
              • 39
              I pulled the Y-buffer & tested it according to that video. I dont have a sound option on my meter. I have it set on diode. I get a reading of .8-1.5 on most pins. Is that the correct setting I should use? What reading would indicate a fault?
                I would try using ohm mode - internal diode bias of meter may give incorrect results. Also make sure you get probes around same way as I did in video.
                • Dowd, Elwood P.
                  • Sep 2013
                  • 39
                  Is the Y-sustain output a certain pin or connector or all 4 connectors? My Y-buffer board is LJ41-07018A
                    Usually it's the connector where all the pins are grouped. There are several lots, -Vsc(floating GND) and Vof(output), the output path is the main output from the Y-main and has the most pins due to the higher current. Typically you want to test from the output to each of buffer outputs. That being said I would not expect a bad buffer on these newer Samsungs to damage a Y-Main and I suspect the board you got was defective.
                    • Dowd, Elwood P.
                      • Sep 2013
                      • 39
                      Ok, thanks. I'm going to borrow a different meter to check it, I don't quite trust mine for something like this.
                      I haven't bought any new boards before so I don't know how often you get a bad one but I would hate to put another one in & fry it as well if there's another problem.
                        What you can try if you get a new board is to test it without the Y-buffer connected. That being said, these Y-main boards can usually handle a shorted -Vsc without damaging themselves. They just go into protection mode.
                        • Dowd, Elwood P.
                          • Sep 2013
                          • 39
                          Alright, Thanks. Just out of curiosity, I put the old Y-main back in disconnected from the X main & Y buffer. It read -190 VSC. I reconnected everything & it still read -190 VSC. Does this change anything or are the two Y-mains still bad but in different ways?
                          • Dowd, Elwood P.
                            • Sep 2013
                            • 39
                            I put the new Y-main back in & tested off the "side" of the VSC test point instead of the center & it reads -188. It's supposed to be -193. Still no change in the picture.
                              That does change things, what happened for it to go from 0 to -190V? Can you try with buffer board installed?
                              • Dowd, Elwood P.
                                • Sep 2013
                                • 39
                                I tested it with everything connected & it still read -188.
                                It it reads 0.00 with the lead like this
                                It read -188 with the lead like this
                                • Dowd, Elwood P.
                                  • Sep 2013
                                  • 39
                                  It must not get a good enough connection for some reason in the center, I cleaned it with alcohol but it didn't change. I assume the VSC was always -188, I just failed to get the reading.
                                    OK. Different tact. If you look at the control board there should be an LED on it. The LED will either blink once a second or light for 5 seconds and dark for 2 seconds, what does it do?
                                    • Dowd, Elwood P.
                                      • Sep 2013
                                      • 39
                                      It stays on for about 3 seconds then goes out. I only left the tv on about 20 seconds but it never came back on.
                                      http://www.youtube.com/watch?v=5ZCNn...u812QMYbQkxRWQ
                                        Well, it sounds like the control board is shutting down but not going into its fault state indicated by 5s on - 2s off. I don't know if these older Samsungs do that, for sure. But the LED should blink once a second if the system is working. I can suggest a control board replacement but I'm not confident it will fix it.
                                        • Dowd, Elwood P.
                                          • Sep 2013
                                          • 39
                                          The buttons on the front (power, channel, volume, etc..) are non responsive. Are they related to the control board?
                                          Seems like it's either the control board or the power supply board at this point.
                                          I found a used control board for $13. I think I'll order it & if that doesn't fix it, try a PSB.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
