50HP66 Again!
  • Odin8989
    • Aug 2013
    • 37
    Re: 50HP66 Again!
    Is there a way to check to see if either of those are the problem or is it a hit and miss kinda thing?
    • Odin8989
      • Aug 2013
      • 37
      Re: 50HP66 Again!
      Oh and it's still doing that gray bar at the top of the screen as well when it does work.
      • freakaftr8
        • Oct 2012
        • 3743
        Re: 50HP66 Again!
        Mayve grey bar is related to mainboard somehow
        • Odin8989
          • Aug 2013
          • 37
          Re: 50HP66 Again!
          So is there something that I can check on the TV to see if it is bad?
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • toddw65
            Sanyo DP5834 - Gray Screen
            by toddw65
            Hey All,
            I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
            Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
            Thanks,...
            10-31-2024, 10:37 AM
          • flashmark
            Smasung smart TV screen brightness reduced and display blueish
            by flashmark
            Recently I had to replace main board of my Samsung 3d smart TV due to issue.
            After replacing it works fine for several days.
            But now it brightness level is almost 50% down. This is not related to settings since I reset the TV (also Energy saving is turn off). Also images and text display in tv is blueish.
            What could be the problem?
            P.S:
            I'm not sure this is affected to the TV.I tried to fix antenna jacket without turning off the TV. I saw when Center core touched metalic-copper shield of coaxial cable, pictures got clearing. I was experimented...
            12-09-2017, 08:10 AM
          • Mark R
            Equipment Display Types
            by Mark R
            Most Displays I have worked with are of course LCD Or Blueish Fluorescent Types. I Have a Marantz PMD800 tuner with sort of a white display. The display area is a sealed rectangular shape in a Glass Case. Looks like some sort L.E.D. display only not your typical section number type. I picked up this Tuner cheap as the display is very Dim. In front of the circuit is a dull red Plastic lens.
            The display is very week and hard to see. I've got my DC 5 Volts allover and also a DC 32 Volt that runs some other section. Power supply looks good front to back. Not familiar with this type...
            06-07-2024, 07:19 PM
          • Chrissygizmo
            jvc lt49c862 firmware needed (I think)
            by Chrissygizmo
            Hi all, ive been asked to repair a jvc lt49c862 , basically when I switch it on it lights up (blueish so it needs backlights replacing) the jvc logo appears then it goes off again but all the while the standby light continues to flash constantly, i tried changing the main board to one from the same model tv but it didn't work at all so I'm guessing that board is broken, I would be grateful if anyone could point me in the right direction...
            Thank you in advance
            02-06-2024, 09:31 AM
