Buffer Board IC replacement.
+ More Options
Posts
  • Glitcher
    • Mar 2013
    • 673
    • USa
    I found a defective buffer board using the beep test with my multimeter. The shorts occur around the circled areas on the buffer board. But I can't figure out which chip or chip(s) are bad and which I need to replace? Can anyone help.
    Re: Buffer Board IC replacement.
    Samsung Q96HD right? The top chip drives odd lines, top of connector, second chip drives even lines, bottom of connector (or vice versa), and so on. I think replacing the second IC from the top would fix the problem, as it appears to drive the bottom most lines, and presumably those are the only ones shorted?
    • Glitcher
      • Mar 2013
      • 673
      • USa
      So the second from the right is the chip? I located one shorted pin from that one, just making sure there aren't any others.
      This is the lower buffer board LJ92-01492A from a Samsung HPT5054
      Found one shorted mosfet on the Y-sus board (88N30W) while the SMD mosfet on the board is still in question.
      • Glitcher
        • Mar 2013
        • 673
        • USa
        Heres a discovery I just made! This is the SMD Mosfet on the Y-sus board (Usually a common fault component)
        My atlas DCA meter isn't able to get a reading off of it. EXCEPT when I heat up the Mosfet. Once it's heated up it gives me the following readings:
        (Left to right, Gate, Drain, Source)
        N-Channel MOSFET
        Test current = 2.50 mA
        Gate threshold Vgs = 3.7V (HOWEVER, as the component cools down the Vgs voltage slowly increases with each test. IE. 3.9V, 4.07V, 4.17V, and after the meter can't read it)
        The Threshold voltage seems to increase as it cools. Does this mean the component is faulty? I'm not exactly sure of the mechanics of how MOSFETS work though.
        Actually I just tried this test on several other FETS that were in a defective pile I kept, and the results are the same! The threshold voltage increases as the fet cools down. When I bought the replacement for the FET I always test it with my meter and it was able to take a reading so I know its not my meter.
        So I guess the FETs may seem to have a good measurement with a multimeter but it won't work as well as its on the verge of failing or until it warms up through the circuit, but I'm guessing it would just get worst until it finally breaks down.
          Atlas DCA55 manual page 55:
          Peak test voltage across O/C (open circuit): +/-5.1V. A MOSFET gate is characterised as "open circuit".
          It cannot test MOSFET Id/VgsON with a Vgs > 5.1V @ Id=2.5mA of which many high power MOSFETs have. It should still detect the device as a MOSFET, though.
          You can check the datasheet of the B20NK50Z here: http://www.datasheetdir.com/B20NK50Z+download
          In particular, page 4, bottom right chart. You can see that a test current of significantly more than 0A (and the Atlas looks for 2.5mA) would require a Vgs of at least 4V. The device will also vary with temperature and drain-source voltage (tested at 25V in the graph, but tested at 5V by the Atlas.) Page 5 bottom left shows a 30% drop in Vgs over 25C to 150C. Note on page 3 the variation in threshold voltage at Id=100uA to be from 3V to 4.5V, a tolerance of +/-25%; Vgs on a MOSFET is very rarely an exact parameter.
          Therefore, the device appears to be functioning exactly as the datasheet characterises.
          • Glitcher
            • Mar 2013
            • 673
            • USa
            When the device passes that 5V threshold, the meter wouldn't read the device as it would cycle on a loop (measuring component... etc)
            Its strange because one replacement I made in the past, comparing two of the same MOSFETs (one was brand new and the other was old, the one on the board) The new one had a threshold of 3V, while the old one was unreadable (threshold of > 5V). However once I replaced the mosfet the panel came back to life.
            When mosfets age, can their increase in voltage threshold cause a problem?
              It theoretically could, but that failure mode is really, really uncommon. The only way I could see it happening is if the gate-source became leaky, and the Vgs the DCA55 could put out fell. As threshold voltage increases, the DCA55 can't turn the device on properly, so it looks like an open circuit or faulty component.
              I have a DCA55 too. It's a nice device, but it has some limitations.
              • Glitcher
                • Mar 2013
                • 673
                • USa
                Hm interesting, I always like the fact that even replacing them it would last a little longer, but I guess it isn't really necessary? I'll be able to save some costs in future repairs then.
                That means I probably have a lot of good MOSFETs in that little pile. So glad I kept them (even though they were bad)!
                  I wouldn't usually reuse MOSFETs pulled from old devices because like capacitors they do have a service life and fail according to a probability function, getting increasingly probable as they age.
                  • Glitcher
                    • Mar 2013
                    • 673
                    • USa
                    True, I would probably only use them for testing purposes though.
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • boosti45
                      Macbook pro logic board replacement parts quesion
                      by boosti45
                      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                      08-21-2024, 05:23 AM
                    • howardc64
                      TCL 49S405 double image
                      by howardc64
                      LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                      This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                      06-23-2025, 03:20 PM
                    • Cvrado
                      Led TV Board Replacement, same part number and model, different size
                      by Cvrado
                      Hello my friends!
                      I have a question that I think you can answer and help me with!
                      I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                      So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                      My concern is that the board won't draw enough voltage to the bac...
                      03-02-2024, 05:05 PM
