Samsung PN50A450P1D Plasma vertical lines any ideas? please help. I attached pictures, the lines go from the top to the bottom of the screen and just on the right hand side.
Re: Samsung PN50A450P1D Plasma vertical lines any ideas? please help
I'd be tempted to say loose panel connector or digital board issue. Reseat the panel connector for that portion on the X buffer. Only do it with power disconnected or you risk further damage.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostI'd be tempted to say loose panel connector or digital board issue. Reseat the panel connector for that portion on the X buffer. Only do it with power disconnected or you risk further damage.
Control board = digital board. Sort of like LCD TV T-con. Usually has a blinking light on it.
You should also try this test to rule out main board:
https://www.badcaps.net/forum/showpo...61&postcount=2
I'd say panel failure is about 25% likely on this (not seen it before personally), if you had a single pixel line or dead bar with pixel lines then I'd call panel 100% dead.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostControl board = digital board. Sort of like LCD TV T-con. Usually has a blinking light on it.
Well I was having success with the lines I got them to disappear, but as I was about to close it up I heard a pop and I seen a spark and after inspection I see what blew, I'm not sure but it look like to be a capacitor on the logic buffer E which the buffer looks like its not replaceable cause the ribbons to the screen are attached to it, anyhow I took a picture of what blew you can see its burnt in the picture also the number on the board of the failed part is C2555 is that replaceable by soldering a new one and if so what value is it? right now its just a black lit screen.
Other values are in parallel with it, they are probably the same. Remove another one and test it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostOther values are in parallel with it, they are probably the same. Remove another one and test it.
"RISK OF FIRE. REPLACE FUSE AS MARKED" gives a small clue.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View Post"RISK OF FIRE. REPLACE FUSE AS MARKED" gives a small clue.
Originally posted by sergio2013 View PostOk, any tips for unsoldering the faulty one and soldering the new one in place? I have one here from a digital board I don't need its exactly the same specs and same fuse. I assume its going to be had with an iron that can only heat up one side at a time. I'm scared of lifting the pads or burning them. Any tips? how about soldering the new one on top of the old one? Do you think a heat gun would work to melt both sides at the same time to pull off the fuse with tweezers
