AOC A42HD84 42" Plasma Bad Picture
  • 1997eclipsegst
    • Feb 2013
    • 99
    • US
    Hey everyone,
    I am working on a older AOC A42HD84 Plasma that turns on and works but the picture is really washed out and dim.
    I have verified the proper voltages on the power supply from the panel sticker.
    Checked fuses on the Y and X main and both are good.
    I ran the set for 15 mins and felt the heatsinks on the Y and X main and both are warm but it seems that the X main is a bit warmer.
    It seems like some of the pixels get "stuck" on certain images then return to somewhat normal (but dim and washed out) when the image changes.
    Not sure what else to check?
    Re: AOC A42HD84 42" Plasma Bad Picture
    Can you see a place to check the Ve, Vset and -Vsc voltages? Also check Vs on power supply directly.
    • 1997eclipsegst
      • Feb 2013
      • 99
      • US
      The power supply has test points for the following and the voltages adjusted to the panel sticker specs
      VA 70
      VS 204
      VSC -190
      VE 84
      Vset 195
      • 1997eclipsegst
        • Feb 2013
        • 99
        • US
        Tested voltages at the connector going to the X and Y main boards
        X-Main
        1 VDD 5.2
        2 VCC 15.0
        3 GND
        4 N/C
        5 VE 84.0
        6 N/C
        7 GND
        8 GND
        9 N/C
        10 VS 204.5
        11 VS 204.5
        Y-Main
        This board was not labeled. Started from top to bottom
        1 204.5
        2 204.5
        3 N/C
        4 GND
        5 N/C
        6 195.2
        7 N/C
        8 GND
        9 -190.2
        10 GND
        11 14.9
        12 5.2
        VA is going to the logic buffers at the bottom of the set and reads 70.2 at the buffer
          OK, can you get a picture of the logic board? This is roughly the same as an LCD panel tcon board.
          • 1997eclipsegst
            • Feb 2013
            • 99
            • US
            Picture of the logic board
              Hmm, it does not have standard test pattern jumper position. On any of the vertical pin headers is there a pictorial indicating a mode to put them in, which they aren't already in? I suspect it may be the 3x2 header but I'm not sure.
              • 1997eclipsegst
                • Feb 2013
                • 99
                • US
                I don't see anything that would indicate a mode for a test pattern.
                The only thing I can see is a number 1 and 3 almost printed on top of each other. It is the same on both sides of the 3x2 header. The other header is labeled 1 thru 5
                • 1997eclipsegst
                  • Feb 2013
                  • 99
                  • US
                  Picture of headers
                    Does anything happen if you press the button on the control board?
                    • 1997eclipsegst
                      • Feb 2013
                      • 99
                      • US
                      Tried just pressing it, holding for 5 and 10 seconds, and powering on with the button pressed and nothing happens.
                        How are the brightness/contrast settings in the user menu? Tried a factory reset? Just in case...
                        • 1997eclipsegst
                          • Feb 2013
                          • 99
                          • US
                          Just tried resetting picture settings to default and tried to adjust different picture settings with no improvement.
                            Do you see Yrr or Yfr adjustments on the Y-main board?
                            • 1997eclipsegst
                              • Feb 2013
                              • 99
                              • US
                              There are 4 adjustment pots on the Y-Main labeled
                              VR5001
                              VR5002
                              VR5003
                              VR5004
                              They don't have any other markings by them. I downloaded the service manual for this set and the one in the manual has completely different Y-Main and X-Main boards.
                                Can you post pictures of the general area around each?
                                • 1997eclipsegst
                                  • Feb 2013
                                  • 99
                                  • US
                                  tom66,
                                  Sorry for the late reply. Here are a couple pictures of the Y-Main
                                    The two left of the transformer (yellow thing printed "LJ26-....") are probably the voltage adjustments, the two right are probably the timing adjustments. Try adjusting voltages to spec, if they are out by more than 3V; then adjust the timings.
                                    • mecha1166
                                      Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                                      by mecha1166
                                      I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                                      07-03-2024, 05:03 PM
                                    • KYBOSH
                                      Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                      by KYBOSH
                                      Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                      No picture but you hear the TV static (white noise) playing loud and clear.
                                      The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                      But it seems they didn't get too far and just left it.
                                      When I first took a look I was amazed at how pristine the inside looked.
                                      Its as if the TV had been in a time capsule.
                                      Caps looked like they were just pulled off the self.
                                      Copper coils had no sign of corrosion on...
                                      02-01-2023, 11:10 PM
                                    • gavric
                                      Vizio M70-C3 Half picture is bad, main board on its last leg?
                                      by gavric
                                      Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                      When tv powers on vizio V logo shows nice on whole screen. picture 1
                                      When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                      When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                      When i click video to start playing picture goes black(like when you change...
                                      09-02-2021, 08:55 PM
                                    • bffargo
                                      2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                      by bffargo
                                      LG 60PB66550 NOV 2014
                                      PSU: EAY63168603
                                      PCB: EAX65359531 2013.11.01 Rev:1.0
                                      Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                      Symptom:
                                      While watching, just went black and started clicking relay every few seconds.
                                      Initial diagnosis:
                                      Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                      Deeper diagnosis:
                                      Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                      09-09-2022, 07:34 PM
                                    • KYBOSH
                                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                      by KYBOSH
                                      Saved this beast from the landfill this weekend.
                                      Manfactured July 2013 in Mexico.
                                      I love working on plasma TVs.
                                      Its been a while but I was lucky enough to find 2 this week.
                                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                      Will start troubleshooting tonight.
                                      10-17-2024, 01:17 PM
