TH-50PX75U NO Video\Sound No Blinks Turns on fine
  • reliantkcar
    • Aug 2013
    • 34
    • usa
    I have a TH50PX75U
    50" plasma tv. it turns on fine and you can see the glow
    it turns on from the remote also
    it just doesn't show a picture or do anything after that
    I checked the service manual and unplugged D5 connector and powered it on
    I get a full white screen so according to that the power,sustain,and D board are fine.
    I'm thinking mainboard or the mainboard isn't getting the right voltage
    any ideas it seems all the normasl issues have a blink code?
  • reliantkcar
    • Aug 2013
    • 34
    • usa
    Re: TH-50PX75U NO Video\Sound No Blinks Turns on fine
    Any ideas the mainboard seems impossible to find anyone selling one?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      I might be selling parts off the one I have, if I can't fix it. Be sure you have a real good idea of what is wrong though. Debugging this kind of tv can be more than tricky (see my other posts on my SD woes).
      • reliantkcar
        • Aug 2013
        • 34
        • usa
        I followed the service manual and when I unplugged the D5 from the main to d board i got a solid white screen which is supplied by the ic on the d board and there were no lines or artifacts and the manual said the only thing it could be is the mainboard.
        and everywhere the power,d board,and mainboard are out of stock so these tv have alot of issues. I should have kept my Yamaha PDM-1 it just had one intermittent vertical green line and was from 2002 and worked perfect....
        • marce002
          Macbook A1465 works fine Linux but turns off in MacOS
          by marce002
          Hello
          I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
          Formating and installing does not work because it also turns off.....
          But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
          So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
          02-02-2022, 05:43 PM
        • ILoveZeroTwo
          LG OLED77B29LA shuts itself down/doesn't start
          by ILoveZeroTwo
          I'm trying to fix a TV that got damaged by rain (open window during a storm).
          The TV at first would start up and work completely normal, with no lines on the screen or anything. But after about 30 seconds, it turned itself off. After it shut itself down, starting it up directly afterward is no longer possible.
          The standby light is red and it blinks once on the power-on command by the remote. The relay also does not click anymore when plugged into the wall.
          Standby voltages are all present and stable, approximately 13V for the 20V line...
          08-07-2024, 09:22 AM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • AustinComputerDoctor
          Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
          by AustinComputerDoctor
          I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
          I see backlite is active,
          but I cannot get the screen to return back to menus , etc
          This is all after replacing the mainboard...
          any assistance is greatly appreciated.
          03-25-2024, 12:43 PM
        • K212
          Samsung QE65Q700TATXXC is not starting
          by K212
          my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
          The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
          I contacted Samsung support who said it is most...
          07-31-2025, 12:45 PM
